  • SN95 V6 Mustang Tech
03 over heating
  • Thread starter Thread starter Phatt_daddy
  • Start date Start date Mar 18, 2020
P
Phatt_daddy
219
Hytop, AL
Mar 18, 2020
  • Mar 18, 2020
The only thing I haven’t done yet is replace the thermostat. My sons 03 v6 auto started dec 18 overheating when he got stuck in traffic. Replaced the fan, radiator, temp sensor, flushed the system, replaced the whole engine ( long story their) and 2 CCRM. When he gets stuck in traffic his car still pegs the gage and coolant can be heard bubbling under hood. No leaks anywhere. What an I missing besides the thermostat?
Thanks,
Nate
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 20, 2020
  • Mar 20, 2020
I would like to get you to slow down. Replace fewer parts. Test more. Two CCRM's? That's a very expensive part to replace on a guess.
HOW did you bleed the air from the cooling system? The V6 is very bad about trapping air inside the cooling jacket.
V6 coolant refilling procedure:
1998 mustang irregular rpm's showing hot
98 mustang was overheating, jerking, running rough and just not sounding healthty. New wires, plugs,thermostat, Air Filter you name it has been replaced along with a radiator, hoses and battery within the past two months. Once the tune up was completed it jerked a little then ran fine for 10...
www.allfordmustangs.com
The other things to check:
  • Have you done a through review of the battery and charging system? Don't cut corners here.
  • Have you confirmed that the cooling system is holding pressure?
  • Is the clean and fresh 50/50 mix of antifreeze in the radiator?
  • Are all of the fan shrouds and air dams in place?
  • In my experience whenever a motor slowly overheats during stop/go driving the usual cause is a clogged radiator. We will "assume" that the new radiator is good.
  • After an over heating event it's always recommended to replace the T-stat.
  • What have you done to rule out a clogged exhaust (cat)?
Howto perform charging system voltage drop test
To anyone else reading any of my posts I usually include the line: Today's cars simply will not run right without a strong battery and charging system! Cut corners here at your own risk I'm a big believer in starting with the basics. As such I...
www.stangnet.com
P
Phatt_daddy
219
Hytop, AL
Apr 3, 2020
  • Apr 3, 2020
The CCRM's were from a pick a part so not that bad. That was part of the issue as after the second one, the fan was trying to kick on. Radiator is not obstructed and is clean and free flowing. Fan was a new one. Bleeding the cooling system- that I was unfamiliar with but have since gotten that part figured out so all's good there. Electrical checked out spot on.
Thanks for the reply and helpful info.
Nate.
T
Titusvillefox89
31
Titusville FL
Apr 5, 2020
  • Apr 5, 2020
Nate.
One more thing to mention is the radiator cap. If you can, pressure test it and make sure it holds. Cooling systems cant do their jobs if they cant pressurize...
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
M
  • mnky99
  • Sep 5, 2025
mnky99
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
