'03 Pulley Swap Question
stangman98
362
Chattanooga, TN
When sawpping to a 2.93 with a new belt have any of you noticed that the blower sound is a bit higher then with the stock belt and pulley? Is that normal? It's a bit more high pitched.
Also when putting th pulley on...was your's exactly flush with the end of the shaft or was the shaft in just about an 1/8" into the pulley??
Need re: ASAP
Im not sure about the space, but you should find out asap. I had mine installed by krazy koncepts in portland who has experiance doing many,you might want to give them a call.As far as the whine I put a 2.76 on mine and she sounds like a jet on boost,but I actually like it.
