'04 Cobra SVT Cold Air Intake
Uncle Meat said:
I have to agree with Yellow Horse on the gears and CAI. 4.10's are too low for this car. The 3.90 seems to be the perfect ratio for 1/4 mile. What are your RPM's in 4th through the traps with those 3.90's?
As for the CAI keep it simple and stick with a straight through design. Easy to install, inspect, and maintain.
U.M.
Your car sounds awsome U.M!!!!!!!!!!!!!!!!!!!!!!
Installed K&N FIPK and no check engine light
After taking back the BBK CAI, I purchased and installed the K&N FIPK. I did ask K&N about it and they had not yet tested it on the '04. It did work without any problems and no check engine line :D . No Screen on the FIPK either, so the dealer was wrong about that being the problem. I did notice that the BBK CAI had smaller tubes going to the filter than stock and that 90 degree turn into the fender well can't be that great for airflow either. I really liked the BBK looks for the CAI, but it proved to be useless on my '04.
Next, I have to install some chassis stiffening and a shifter. The wheel hop is killing me and I really hate the stock shifter. If I were to do a smaller pulley, I would have to get 315 tires to get it to hook. On stock tires it breaks pretty easy (but it was worse with the stock gear).
Car looks and sounds great! Being a convertible, it is a bit of a sleeper.
'04 Mystichrome Convertible
BBK Long Tube Headers, X-Pipe and high flow cats
Magnaflow Catbacks
SCT Base Tune
4.10 gear
K&N FIPK
Badstang00 said:
I installed the JLT CAI, mated to the K&N FIPK. A little bit of a PITA to put on, but it works and looks great IMO. The only problem I had was not being able to get the heat shield in, it will have to be cut to fit.
-Mike
Have any pics of this? Is it the CAI or RAI from JLT that is matched up with the K&N FIPK?
U.M.
Agreed that straight through CAI is better. Avoid the ones that go through the fender.
I wouldn't even consider 4.10's unless you were running a 28" slick
