  • SVT Tech Forum
04 IRS
  • Thread starter Thread starter fox racer
  • Start date Start date Oct 16, 2007
fox racer
577
Staten Island, NYC
Oct 16, 2007
  • Oct 16, 2007
Hey guys, I'm new to the whole IRS scene, but I might be getting my hands on an IRS rear out of an 04 Cobra to put in my Notchback. I just have a few quick questions:
1) Is there any way to tell the difference between, say, an 03/04 IRS and a 99/01 IRS?
2) Are there any mods I should do prior to the install of the IRS?
3) What are some weaknesses of the 04 model, that I should be looking ro upgrade first.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Oct 16, 2007
  • Oct 16, 2007
03/04 has beefier 31-spline axles I believe and a larger torque brace than the 99/01.
Depends on your intended use. Level 5 half-shafts, poly bushings, IRS brace, pinion snubber, etc.
Besides the half-shafts themselves the rear diff covers get blown out under hard launches. Again an IRS brace can help prevent this.
U.M.
fox racer
577
Staten Island, NYC
Oct 16, 2007
  • Oct 16, 2007
Thanks UM. The car, for now, will be a street car, hovering around 300hp/320ft/lbs torque. I was thinking about MM Poly bushings (frame bushings), MM upper mount support (that peice of metal that is welded to the upper mount), and the Diff case brace. I read your post on how the case flexes so much that it cn break the seal, so I figure easier now then later.
I have very little hands on experience with the IRS setup, are the differences in years easil visible, or should I bring someone more knowledgeable to help me when I purchase it?
W
WhiningCobra
New Jersey
Oct 21, 2007
  • Oct 21, 2007
if you aren't going to road race or daily drive the car. i suggest you'd stay far away from a IRS. they're a pain, it clunks and it'll snap even on a slight launch. and it just adds weight. if i can do it again. i'd get a solid rear.
VR4
vancouver, wa
Oct 21, 2007
  • Oct 21, 2007
01s also have 31 spline but im pretty sure the 03/04 shafts themselves are bigger than 01s
bushings in 03/04s are slighty stiffer but i doubt youll notice the difference.
biggest weakness is the diff cover. BF IRS brace works wonders. considering youre putting it in a fairly light car i personally wouldnt worry too much about the halfshafts. i would do all the bushings in poly/delrin before installing it though.
J
What's it Worth? Cobra IRS
  • johnnyj331
  • Aug 25, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Aug 25, 2025
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
What is it Worth?!?!? May 18, 2026
nickyb
Warhorse Racing YT Channel
  • Warhorse Racing
  • Aug 19, 2024
  • Stangnet Television
  • 2 3
2K
Stangnet Television Apr 16, 2026
Warhorse Racing
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:38 PM
TTSaleen
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • SVT Tech Forum
