  • SN95 V6 Mustang Tech
'04 V6 running rich excessively on both banks
  • Thread starter Thread starter 04DSGVert
  • Start date Start date Oct 26, 2025
04DSGVert
Florida
Oct 26, 2025
  • Oct 26, 2025
So my car runs excessively rich. Idles and accelerates poorly. If you shut off the car and within 5 seconds turn it to Key On Engine Off, you'll hear a loud pop. The SCTX4 scanner I have shows the fuel is constantly being leaned out. It's going from 1.00 to .65 just 5 minutes into drive. I am sure that if I kept driving it would keep taking away fuel until it stalled out. You can even smell a strong gas stench from the exhaust... I'm surprised it even ran at all like that... car is 3.9L V6 with 126k miles.
I did replace the fuel injectors, fuel filter, FRPS, coil pack, spark plugs, o2 sensors, a faulty IAC, all vacuum lines... I'm sure I'm missing something. MAF has been cleaned and all sensors have correct voltage. Fuel pump is original but has no issues... yet
I'm getting a P2196 and P2198 code and the throttle response is sputtery and surges to a point it kicks on the traction control. Recently checked the oil and it smells just like the exhaust... rich with gas. The oil is basically thinned out enough to drip like water.
I parked it up for now so I don't wreck it. I'm not sure what could be causing this?
Any help would be appreciated.
Thanks
Sorry for the paragraphs
RaggedGT
Mod Dude
Jul 20, 2014
4,756
3,213
203
Taylorsville ky
Oct 26, 2025
  • Oct 26, 2025
Thanks
Un metered air ,vacuum leaks,stuck fuel regulators, purge solenoids/valves. Those are the most common issues to cause rich/fuel dumps etc
04DSGVert
Florida
Oct 27, 2025
  • Oct 27, 2025
Where would I find the purge solenoid/valves and how would I check if it is stuck? I've not messed with the EVAP system yet.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
A
Car is running bad
  • Anthony3511
  • Apr 30, 2025
SN95 V6 Mustang Tech Apr 30, 2025
89ripper
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
