  • SN95 4.6L Mustang Tech
04gt 3650 Oil Change
  • Thread starter Thread starter LouisianaZJ
  • Start date Start date May 29, 2005
1 of 2 Next Last
LouisianaZJ
237
May 29, 2005
  • May 29, 2005
I'm getting close to 10k miles, so it is probably past time to drain the trans fluid.
Castrol/valvoline/penzoil, etc Dex/Mercon III fluid ok?
and how much do i need? 4 quarts?
Pearl02
496
Kansas City
May 29, 2005
  • May 29, 2005
Read your owners manual. You shouldn't have to change the tranny fluid for awhile. It's synthetic. Pearl02.
Give Me TP
936
Republic of Texas
May 29, 2005
  • May 29, 2005
3L (3.2 Quarts) of Dexron III
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 29, 2005
  • May 29, 2005
mobil 1 ATF, thats all my 5 speed ever sees.
Mustang5L5
Mod Dude
Feb 18, 2001
43,257
17,941
224
Massachusetts
May 29, 2005
  • May 29, 2005
you should be able to get a lot more than 10K miles between trans fluid changes
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
May 29, 2005
  • May 29, 2005
ya i think its about 30k according to the manual. i usually do mine once a year though.
LouisianaZJ
237
May 29, 2005
  • May 29, 2005
yeah, probably
it has 1 yr but it is like 90% city driving
StangPro
441
Roseville, MI
May 29, 2005
  • May 29, 2005
Factory fill is Mobil1.
Unless you use Royal Purple, Amsoil or Red Line you can almost expect to have shift problems or noise as the 3650 has some issues.
Fluid swap procedure here:
http://www.stangpro.com/html/tutorials/other/transfluid.htm
Mustang5L5
Mod Dude
Feb 18, 2001
43,257
17,941
224
Massachusetts
May 29, 2005
  • May 29, 2005
That's why i kinda say "If it ain't broke, don't fix it"
Some guys actually make their shifting problems worse by changing the fluid depending on what type they use.
I beleive '04 was the first year ford put Mobil 1 in there fromn the factory.
I should really do a fluid change myself...but you know what they say. "If it aint' broke....."
StangPro
441
Roseville, MI
May 29, 2005
#10
  • May 29, 2005
  • #10
All 3650's had Mobil1 and they all have issues.
Sticking with Mobile 1 isn't a bad choice, but there are better options.
SilverGTV8
295
West Brookfield, MA
May 30, 2005
#11
  • May 30, 2005
  • #11
I used royal purple ATF and have had no issues.
hotrodnut
672
North Florida
May 31, 2005
#12
  • May 31, 2005
  • #12
I'm having good luck with Motorcraft MERCON ATF #XT-2-QDX at 3.7L.
2k2fourpointsix
210
Quincy, MA
May 31, 2005
#13
  • May 31, 2005
  • #13
Ive been dealing with the notch 1-2 shift since my car was new, just last nite at 34k on the odo I finally swapped out the fluid and put in some royal purple, 4 qts. I know they changed the fill level to 3.2 but I think that was a band aid fix and would prefer to have it full. I was reluctannt to swap the fluid b/c I didnt think it woul actually improve the shift quality that much, well i was wrong. I never thought it would work so well. The tranny is much much quieter now, and the 1-2 shift quality is great. I didn't realize how loud my tranny was untill after the RP fluid. My recomendation is RP all the way well worth the cost and 40 mins to change it.
trinity_gt
3,125
81
99
Canada
May 31, 2005
#14
  • May 31, 2005
  • #14
2k2fourpointsix said:
Ive been dealing with the notch 1-2 shift since my car was new, just last nite at 34k on the odo I finally swapped out the fluid and put in some royal purple, 4 qts. ...
You're talking about Royal Purple Synchromax, right?
2k2fourpointsix
210
Quincy, MA
May 31, 2005
#15
  • May 31, 2005
  • #15
Yup its the only stuff I will use from now on.
05SonicBlueGT
36
Mississippi
Jun 6, 2005
#16
  • Jun 6, 2005
  • #16
I have the 05 GT and I'am looking to improve the car all I can, has anyone tried the Amsoil for the Manual trans. or rearend?
hotmustang331
2,967
Bastrop,TX
Jun 6, 2005
#17
  • Jun 6, 2005
  • #17
I have 22890 on my 04 and havnt changed it...but i will throw in some RP when i change it...have RP in my rear axle and it works great.
trinity_gt
3,125
81
99
Canada
Jun 7, 2005
#18
  • Jun 7, 2005
  • #18
Been doing more research. Everything I've read or seen on the 3650 indicates that one is to use ATF in it: e.g.
- 2002 GT shop manual states Mercon Synth ATF
- this http://www.fcsdchemicalsandlubricants.com/fad/quickref/mantrans.pdf
- TSB 04-15-6
and so on. And people are putting synchromesh gear oils in (e.g. Royal Purple Syncro Max versus Royal Purple Max ATF) and getting better results??
Does anyone know Tremec's position on what fluid to run?
hotrodnut
672
North Florida
Jun 7, 2005
#19
  • Jun 7, 2005
  • #19
I called Tremec and talked to John, he said do not use GM Syncromesh (he did not mention RP Synco Max) because it swells the fiber material used in making the Synconizers in the 3650 transmission. He said use Mercon III / Dexron III at a quanity of 3.0 to 3.2 ltr. I now use Motorcraft MERCON ATF #XT-2-QDX but I could not bring myself to lower the fluid level from the specified 3.8L of the '03 owners manual to what he suggested. I did fill it to the 3.7L as specified in the '04 owners manual though.
He said the specified fluid of Mercon Synthetic or any synthetic, is too slippery and there is not enough friction for the syncronizers riding against the dog rings to get them up to speed to match gear engagement. That is why the TSB and the new '05 Manual states using Motorcraft MERCON ATF #XT-2-QDX fluid.
2013 Geee T
805
Oak Park, CA
Jun 7, 2005
#20
  • Jun 7, 2005
  • #20
I had tried Redline in mine and it acutally made it a little worse. Then I went to Dexron III and it helped it out.
1 of 2 Next Last
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
2K
Other Auto Tech Jun 13, 2026
427nostang
