05 Dash Rattles...TSB Anyone?
120rir
53
Love my 05 and had some things taken care of early on according to TSBs posted on this site. However, has anyone seen any TSBs related to ongoing rattles and vibrations in the dash? I kind of doubt it and I am assuming Ford is going to leave it up to the owners to deal with them or just learn to live with it but if they acknowledge the problem and are willing to fix it all the better.
This is my first post. but have been looking at these boards since prior to buying the car last july.. I have this same problem it comes from the driver side if i put little pressure it stops but i have to blair the radio to cover the annoying rattling sound up. YES i have this problem aswell
Mine rattles on the passenger side... one of my buddies told me he thought the sound was coming from where the dash and windshield met, kindof hard to pinpoint myself seeing how I'm never the passenger in the vehicle. Later
Cathane
just ran them this is all at this time
Technical Service Bulletins
2005 MUSTANG - US (English)
05-25-15
MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
05-24-6
CONVERTIBLE SYSTEM CONCERNS
05-23-17
DIAGNOSTIC TROUBLE CODE (DTC) P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-21-2
LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
05-20-2
REAR AXLE NOISE
05-19-10
LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10
BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-12
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
05-15-13
FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12
FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005
05-15-8
TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
05-15-2
GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-14
CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-6
EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
WELD BONDING PROCEDURE
04-24-20
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
05 rattles
I have experienced the same noises from passenger side. This window area sounds like the ticket since it also goes away when pushed on. Will see what dealer has to say.
Taking my car toay with a list of 14 things...ouch. I wish Ford would step up, pay the techs the same for warranty work and let them replace the parts on the first or second go around. Some on my list are 4th attempts. With less than 9200 miles, it's a bit hard to swallow.
I do love the car, still smile while driving down the road. Makes it worth the while.
God Bless America
Indeed, this passenger side rattle is annoying!! I haven't worked much at figuring out exactly where it is, but it's "above the glovebox" as a general area...
I'd be most interested in what you learn from the dealership, too!
BennytheJet said:
Is your rattle on at all times because I have a rattle on the passenger side too, but only whe I hit +3000 rpms?
My rattle is not there all the time---it seems to be a function of the temperature, the condition of the road, the speed of the engine, and the speed of the car. So---sometimes it's there, sometimes it's gone! This morning (about 42 deg. or so) it was really annoying as I was driving to work.
Mine rattles on the driver side all the time. Mainly when the there are any imperfections in the road. It squeaks and rattles like there is no tomorrow. It is starting to get annoying, especially since it's basically a brand new car.
It would appear many of us are suffering from the same condition...and I'd be willing to bet it's the same with the GT since the interior construction (as is most of the car of course) identical. The dash rattle seems to be coming from two places; the driver's side and the passenger. Light pressure on either side stops the rattle which, at least in my case, occurs variably according to temperature and road conditions. Clearly, there is a very, very small space that's there and it doesn't take much for the rattle to come and go. How difficult would it be to get under the dash and jam some foam rubber up in there?
The car is back and no major updates. Since the noises were intermitent, they could not figure out where they came from. They did not appear during the service drive, nor have they appeared since...go figure :-)
New front brakes and the shaker 500 were replaced since I had the TSB's for those. The dash issue is attributed to possible weather conditions ie: cold/hot. I found that having the research prior and being VERY specific as to the location and type of noise help the writer explain the service request.
It seems the service received depends on the dealer and your own ability to explain the situation. I have gone to 2 dealers now and both have been accomodating and willing to see that the customer is happy.
:flag:
It si the same with the GT. My passenger side dash rattle comes and goes with tempurature and road surface. It's driving me nuts - but turning up the radio solves it. LET ME KNOW WHERE TO JAM THE FOAM!
Dash rattle fixed under warranty
I had a dash rattle coming from the passenger airbag locale. I took it in and the dealer fixed it under warranty. There were some support members in the dash that they uninstalled and then reinstalled. Easy fix.
