0Hooking Up Air/Fuel Gauge ... Where does sender wire go?
mustang90
1,209
15
58
Im hooking up my air/fuel gauge in my 98 mustang gt and need to know where to hook the sender wire up to? In the past I heard to tap into the oxygen sensor white wire, is this correct? Thanks!
I hooked mine up the to ECU, the O2 sensor didn't work.
I used pin 87 because it was the easiest to tap into. Either one you use will gave the same reading since the A/F ratio gauges are pretty much a light show anyway..... :)
Thats what I have been told .. :rlaugh: They really light up the dash and are for looks more than performance readings! Thanks for your help guys, that web site helped out a ton :D
