how do the 1/4 window moulding covers fit, quality,etc.. mine are dry rotted a little, and I would like to use one of these kits, if they turn out looking good. so how did yours turn out ? do you have any pics? was it hard to do? thanks in advance.
SmockDoiley said:Did you just paint them or did you sand too. I think I need to do something with mine because they are pitted. What grit should I use and what technique. Can I just use any paint thats designed for flexibility.
Iowa91LX said:Most all good basecoats will cover up to 320grit scratches. Absolutly no need to go up to 600grit. 600grit is a finishing grit for high quality paint jobs, or else 500wet. These are moldings here not a high quality base/clear paint job, stop sanding at 320grit.
thanks. I guess if I mess them up sanding and painting, I'll just have to get a new set.
ponyboy19 said:how do you get them off the window to paint them or do you mask them off and paint them while on the car?
