Just like the title says, can I run aftermarket 1.6's and use my stock valve covers or do I need to modify them? thanks
Nick
Nick
I am having a hell of a time getting my Scorpion stud mount 1.6rr to clear my stock covers.
jackchan said:Pedistal mount rockers are larger, and stick up farther than bolt downs! Ben
ped mounts are bolt down
jackchan said:thats because, no matter if you have 1.6's or 1.7's when you go to comp cams or anyother brand its all different. Like buying tires after putting on different rims.....they aren't all the same, no matter who says "they didnt have problems" or who says "they did have problems". Pedistal mount rockers are larger, and stick up farther than bolt downs! HOWEVER, if you take out all the webbing under the valve covers and the baffles....they will clear.....here is a few pictures to prove it!
Thanks and good luck
Ben
What did you use to grind them out?Curse said:Ben was right, I had to remove all the reinforcements and then some to get the Scorpions to clear. Not sure how true this is, but I've heard the 92-93 valve covers don't have the reinforcements. I would look for some of them, grinding those things out was a PITA.
SilverFoxbody said:STOCK rockers are 1.6...so yes...duh. And most 1.7's will clear, if not, then you just cut the baffles.
What didn't I use is a better question. What worked best for me was an air grinder for the easy to get at spots, a Dremel tool with an aluminum oxide grinding wheel(buy a lot of these, they run out fast) for the hard to get at spots and a metal cutting bit for the Dremel for the impossible to get at spots.Marlboro_Man said:What did you use to grind them out?
I wish I had known, I would have looked for a set, or gotten a set of aftermarket covers from the get-go.5spd GT said:Curse, my 93 valve covers don't
have "reinforcements"...better clearance. Easier on the grinder![]()
