1.7 roller rockers and stock cam?
They will work and raise your stock cam up to about 472/472 Lift.
You might think about upgrading your springs for sure, and mabye even retainers,etc...
Another thing you have to worry about is fitting them under the stock valve covers. If your stock valve covers are the 91-1/2-93 Style ones with no ribs you should be ok. Or you can grind the ribs off of your other ones, you might have a problem with th the oil baffle too. You can either buy after market ones, Or also get thicker Valve cover Gaksets.
