1.7rr
  • Thread starter Thread starter fiveohGT
  • Start date Start date May 5, 2005
F
fiveohGT
353
Fairfax Virginia
May 5, 2005
  • May 5, 2005
I just ran a search and didn't come up with anything. This is a pretty broad question but I was wondering what advantages there are (if any) to having a 1.7 roller rocker instead of 1.6?
So if someone were to run afr165's, Performer RPM II, FTI cam and 1.7rr what would be the difference if 1.6rr were ran instead?
If someone were to run afr185's, Performer RPM II, FTI cam and 1.7rr what would be the difference if 1.6rr were ran instead?
If someone were to run afr185's, Performer RPM II, Trickflow stage 2 cam and 1.7rr what would be the difference if 1.6rr were ran instead?
Sorry for the questions, I'm just trying to develop an understanding of what the outcome of 1.7rr will be.
What needs to be done to successfully swap in 1.7rr's? new rods, etc.
vristang
4,933
101
124
Seattle
May 5, 2005
  • May 5, 2005
Multiply the 1.6 or 1.7 by the advertised lift of the camshaft. This will give you the lift seen at the valve. The downside to 1.7rr is that piston to valve clearance can be an issue with big cams or shaved heads.
I don't think pushrods are usually necessary.
Roller Rockers (at any ratio) will ruduce friction in the drivetrain, thereby improving power/efficiency.
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
