Just got my car back after the tranny rebuild on Mon.
I've babied it for a few hundred miles, but tonight I couldn't help myself anymore.
I found a long, empty driveway (golf course) and did 2 practice launches and WOT runs. I only did it twice, so didn't really get to develop any techinque.
I've never driven any car down a strip, so it's all new to me.
T R A C T I O N I S D E F I N I T E L Y A N I S S U E ! ! ! ! ! !
launchng from D, I foot braked to around 2000 rpm's. I know, I could've and should've gone higher..., I mashed it and it just burned the tires for a good distance, then took off pretty good... much better than before.
Then, put it in 1, foot braked to 2000 (
), then mashed it and the tires started SCREAMIN' and kickin' out to the side, RPM's shot up to 5500, by then everything was a blur, and I ended up snapping the shifter all the way into OD instead of D!! Doh!
That sucked.
But the good thing is that I was so distracted by the insanity of the new tranny that I lost all common sense! now that I've experinced it, I'll be able to try it again sometime with a clear head!!
Anyway, this brings me to my question:
It's painfuly obvious that I have to work on my launches, but as far as the transgo kit is concerned, can I still do the 1-D-1 now?
I only did it about a dozen times before the rebuild, but I wasn't sure if I could do it with the transgo kit "safely" or not.
Thanks for any reples, and if you happen to have any AOD (w/ street tires) launching advice, that'd be great too!
J
), then mashed it and the tires started SCREAMIN' and kickin' out to the side, RPM's shot up to 5500, by then everything was a blur, and I ended up snapping the shifter all the way into OD instead of D!! Doh! That sucked.
J
