10.37 compression on pump gas
  • Thread starter Thread starter 93stang burden
  • Start date Start date Feb 21, 2011
93stang burden
82
Fort Bragg, NC
Feb 21, 2011
  • Feb 21, 2011
can you run 93 octane on 10.30's compression ratio without pinging??
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Feb 21, 2011
  • Feb 21, 2011
what heads?
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Feb 21, 2011
  • Feb 21, 2011
yes as long as u don't try to go crazy with the timing.
LarsD
2,680
119
123
Texas
Feb 22, 2011
  • Feb 22, 2011
I was able to run 89 octane with gt40P heads pushing almost 10:1 compression. With the right chamber and aluminum heads I don't see why not.
Wildstringer
65
  • Feb 22, 2011
there's always E85. I haven't done alot of research on what needs to be done to run it.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Feb 22, 2011
  • Feb 22, 2011
With reasonable timing, yes. There are lots of 11:1-11.5:1 cars running pump gas. It's all in the tune.
9
90stang5speed
582
Columbus Ga
Feb 22, 2011
  • Feb 22, 2011
You need to tune for E85. Its stoic ratio is around 9.something instead of 14.7 like gas so you will also need bigger injectors
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Feb 23, 2011
  • Feb 23, 2011
dynamic compression ratio (determined by the cam intake valve closing event) should be looked at - could be a non-issue.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
