10.5:1 compression. How much total timing???
cojo428
810
NH
I am running a solid lifter 347 with a 10.5:1 compression ratio. I recently switched to 110 leaded fuel and bumped timing to 40 degree total timing. Anyone have a similar setup? I am just looking to hear what other ppl are running. Thanks!
In the past I've run 36-38 degrees of timing in my "hot" carded set ups. 40 is in the ballpark. If you can make it to the track your best bet is to test it out each way and see what you come up with.
MY MPH at the track didn't change much, but it was bad air. 85-95 and really humid. I don't see much of an indication good bad or otherwise on the plugs. I also went up 2 sizes on jets with the bump in timing so it was really to many changes to get a good indication. I wanted more fuel and maybe a wisp of black smoke between shifts anyway.
They are track heat aluminum heads. I think I am going to back it off to 38 then try it one day I can get a few runs in at the track. I just thought I'd catch someone with a similar setup.
Thanks for the input!
