  • 1994 - 1995 Specific Tech
10.5s in back?
  • Thread starter Thread starter wafrodon
  • Start date Start date Jul 11, 2005
W
wafrodon
  • Jul 11, 2005
will i have trouble fitting 10.5 in cobra Rs in the back. Will i need spacers or will they be fine. it is the rim made by OE concepts.
bimmertech
1,123
merriam, ks
Jul 11, 2005
  • Jul 11, 2005
did you take off your quad shocks?
P
pat farina
11
British Columbia
Jul 11, 2005
  • Jul 11, 2005
I have them on my car,and the quads are still on,if you go to a bigger tire 305 or 315 they will rub and most likely you will take them off(i have 295's)no problems
Joe 5.0
1,184
Macomb, MI (metro detroit)
Jul 12, 2005
  • Jul 12, 2005
I have 17x11's in the back with Nitto 315's. It rubs a tiny bit on the quads and tailpipes, but nothing I cant live with.
Methodical
1,192
11
59
Clinton, MD
Jul 12, 2005
  • Jul 12, 2005
What do you do when it comes to rotating tires?
CManT1914
3,172
Killeen, Texas
Jul 12, 2005
  • Jul 12, 2005
It's not a good idea to rotate your tires on a mustang. If your back tires are bad, and you put them on the front, bye-bye cornering. I tried it, it sucks. Since I won't ever rotate my tires on the stang again, I also run 315's out back.
M
MM&FF Stang
10
  • Jul 12, 2005
Go with the 315s, i had them and they were great!! Look much better. Only thing i did was hammer the inner fender a little bit to eliminate the rubbing... other than that its all good
blksn955.o
3,263
st.louis mo 314
Jul 12, 2005
  • Jul 12, 2005
I have the same rims as jtkz13 and also run a 315 tire. I had to flip my quad shock and other than a little hammering (about 2min for both sides) to a part of the wheelwell in the back I have no rubbing issues. I also have 2 1/2 I/D exh.
Methodical
1,192
11
59
Clinton, MD
Jul 13, 2005
  • Jul 13, 2005
If your back tires are bad I agree. But if you are rotating your tires consistently and they are the same size then why is it bad to rotate tires on a mustang. I don't get it. I rotate my tires every 5K miles and they have good wear patterns. But I do understand that if you have wider tires in the back than the front you can't rotate them. But if they are the same size why is it bad to rotate tires. Peace
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
2001 SVT Cobra Decision Time
  • Mec
  • Aug 13, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 14, 2026
nickyb
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
