My '84 GT is ready for a new clutch. I was wondering if the switch to a 10.5" arrangement was a quick and easy bolt in replacement for the 10". If so, what parts will I need?
maverick0716 said:All you need is a 10.5" flywheel from an 86+ 5.0L mustang.
I heard that but when i did my t-5 swap my clutch wouldnt work because the clutch disk would not work with the early flywheel. i had to buy an 86+ flywheel to use the 10.5SPEED FREAK said:the holes to mount the 10.5" clutch are on the early fly wheel they just need to be tapped and you can bolt the 10.5" clutch to the early flywheel. Make sure you resurface your flywheel tho.
RsStanG1987 said:I heard that but when i did my t-5 swap my clutch wouldnt work because the clutch disk would not work with the early flywheel. i had to buy an 86+ flywheel to use the 10.5
Daggar said:Unless you're planning a drag strip ONLY car, then stick with the steel. the lightweight flywheels cause drivability problems for street vehicles. Even the billet steel are not worth installing on a street car unless you're involved in a mototr sport where an SFI approved flywheel and scatter shield are needed.
Realmongo said:How about the Ford # FMS-M-6375-B302 iron flywheel with the 50 oz weight?
