A question for brake experts. Something odd with my new brakes, please help me out, may be i am missing something...
Here is the situation: I have put together a brake upgrade: Brembo X-drilled/Slotted Cobra rotors (from ebay) and SVT cobra caliper kit (http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6455).
1st thing i wonder about: The front rotors on a 2001 GT are 11.65 correct? New rotors are 13 in. That install went fine - brakes bled and tested. Works fine. Two things seem odd - i am not noticing a dramatic difference in braking! It seems a bit better, but not by much... Is the upgrade not that big? And another thing - the area of the brake pad that is touching the rotor is about 75% of the available rotor area. Is that normal and as expected? Or are my pads smaller then needed?
2nd: New rear rotors were as big as the old FRONT ones, so about 11 in. They didnt fit. Looks like i either need a bracket to mount the calipers or different calipers alltogether. Is that correct? Is the 10th edition Cobra rear brake caliper mount different from a GT? Take a look at this kit http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=6455. Was it even worth for me to put the rear one on? I left the stock rotor and put the red caliper on.
Is this WHOLE package as i described it even a good upgrade? I thought i got a good deal on it - for 600 bucks all brand new. Was it worth it?
All the help is very much appreciated!
Thanks
Thanks
i installed the setup w/ the stock brake lines, then went back a week later ans installed a set of Russel SS lines. i found a huge difference with those. it made the pedal a lot stiffer and more responsive. as for the rear, i would swap out some aftermarket rotors in the cobra size (11"?) along with the new cobra red calipers. i *think* the rear cobra calipers mount differently than the GT calipers. i havent done mine yet, so im not real sure.
