SOLD '11-'14 Mustang - Blowfish Racing Manual Shifter Support Bracket
This includes both the race version and street version brackets for either a hard mount with zero movement or rubber mounted for some NVH dampening. Very slightly used, like new in box with less than 600 miles of use. Looking for $250 shipped.
Blowfish Racing Manual Shifter Street Version Support Bracket for your 2011, 2012, 2013 and 2014 V6/GT Mustangs or 2012-2013 Boss 302 Mustangs.
Transform the poorly designed MT82 manual transmission in your 2011-2014 Mustang into a world class performer with help from Blowfish Racing and their All-New Street Version manual shifter support bracket! This bracket is the definitive answer to alleviate all your MT82 transmission problems while providing all the benefits of the original model, but now featuring decreased levels in NVH (Noise, Vibrations, and Harshness).
Blowfish Racing redesigned the new street version support bracket as an easy way to transition the MT82 manual shifter from being a remote shifter in to a solid mount setup. Essentially, this bracket allows it to function just like a T-56 or T-5. No more grinding gears, high RPM lockouts or missed shifts. Pick up Blowfish Racing's original version support bracket at CJ Pony Parts and you’ll gain the confidence of knowing that your Mustang's MT82 transmission will go into the gear you intended it to, precisely when you need it to!
Features and Benefits:
- Patent pending design modifies the semi-remote mount shifter configuration for a rigid mount to the transmission
- Improved rear clamp design utilizes an isolation mount to help eliminate noise
- Redesigned MGW mount prevents contact with the body studs in the transmission tunnel
- Drastically improves shift accuracy, even with a stock shifter
- Realigns the 1-2 shift gates to prevent gear change grinding
- Prevents those annoying high RPM lockouts
- Prolongs synchro life
- Integrated NHRA legal driveshaft safety loop
- Works with stock and all aftermarket shifters
- Ford blue powder coated finish
- Includes all the necessary mounting hardware
- Installs painlessly, with basic hand tools
*Will NOT work with the MGW Race Spec Shifter
Order Blowfish Racing's Manual Shifter Street Version Support Bracket for your 2011, 2012, 2013 or 2014 V6/GT Mustang or any 2012-2013 Boss 302 Mustang from CJ Pony Parts and start enjoying clean, precise shifts without grinding today!
Price drop, $225 shipped
As mentioned, comes with both bracket sets, the street version (lower left in photo) for NVH dampening and the race version (lower right in photo) for the firmest feel.
