i spun the entire time in 1st gear, so i'm hoping with some drag radials to hit 13.8 and with gears to hit 13.5. i was launching at 2000 rpm. 2.2-2.4 60' times, i think if i get my launch down i'll be good.
bergs said:i spun the entire time in 1st gear, so i'm hoping with some drag radials to hit 13.8 and with gears to hit 13.5. i was launching at 2000 rpm. 2.2-2.4 60' times, i think if i get my launch down i'll be good.
2001 Geee T said:Did you just post this time on another board which I am not allowed to name to avoid breaking rule #1?![]()
kirkyg said:bergs, something isn't right here. Your posting 97 mph for your 1/4 mile. Most stock 99+ gt's will run 99 mph or so stock. And even moreso, that mph will INCREASE if your 60 ft is bad. Judging by your times id say you could easily run 13.7-13.8 stock IF your times are accurate which im questioning. Maybe something was off with the track equipment but something aint right. I ran 99.5mph with just catback and shifter mods which means basically no additional power and i didn't spin at all on my best 14.02 with a 2.15 60 ft. Your mph being nearly 3 mph lower than me suggests your closer to your peak than me however your 60 ft suggests the opposite.
kirkyg
Drag radials will lower your 60ft and drop you into the 13's but your mods with DR's should put you had mid 13's without gears. Not bad for the first time out though. Keep practicing and good luck!bergs said:from the timeslip:
60'-2.225
330-5.997
1/8-9.147
MPH-78.26
1000-11.846
1/4-14.132
MPH-97.38
4.6 Rocket said:From the looks of it your 1/8 times are good and with a decent trap speed. Something is going wrong in third for you to only hit 97mph
bergs said:mabey i am letting off the gas too soon, or mabey i should be shifting into 4th? do you guys shift into 4th?
add a midpipe and LCAs to the list and you'll definately be dipping in the 13'sbergs said:i spun the entire time in 1st gear, so i'm hoping with some drag radials to hit 13.8 and with gears to hit 13.5. i was launching at 2000 rpm. 2.2-2.4 60' times, i think if i get my launch down i'll be good.
