  • SN95 4.6L Mustang Tech
15*8 what radials
  • Thread starter Thread starter CENTENNIALSTANG
  • Start date Start date Oct 3, 2006
C
CENTENNIALSTANG
Houston
Oct 3, 2006
  • Oct 3, 2006
I just got some 15*8 inch rims i was wondering what size of drag radials to go with. And what size of slicks to get for the track.
BennyBlown2v
1,233
Carmel, INdiana
Oct 3, 2006
  • Oct 3, 2006
So you want drag radials for the street and slicks for the strip?? You should want either/or for the strip...neither for the street really.
Annnnyway...as far as drag radials, Mickey Thompson ET Street Radials in 275/50/15 would be good, that's a 26" tall tire. If you're running lots of gear (4.10's or higher) you may want a taller tire such as 255/60/15 (27") or 275/60/15 (28").
275's are fine on that wheel if you're worried about that being too big. I run 275/40/17 DR's right now (gonna sell and buy some slicks though, or save them and use them as summer street *cough*race*cough* tires).
BooWFO
991
Louisville, KY
Oct 4, 2006
  • Oct 4, 2006
for dr sizing I agree with Benny
for a slick a 10.5 will work Of course I'm thinking about going to a 8.5 or 9" slick next time around.
Now if you want a bias ply and a dot stamp Et streets ( orginals not the dr's) work great, just don't get caught in the rain.
stangman
2,690
10
69
in a 3 bed, 2 bath
Oct 4, 2006
  • Oct 4, 2006
i have some 15x8 prostars with 28x10.5 ET drags, sitting on the car right now i wouldn't go any bigger than that on that size rim, but that's just me
Jackie Chan
I didn't read this.
2,507
Orlando, FL
Oct 4, 2006
  • Oct 4, 2006
are these just for the strip?
if you are into racing different classes i would go with the et street drag radial. if you are just looking for a tire to drive to the track and get some runs in and have the best results i would go with a bias ply like the hoosier or et street. i think they are more forgiving on your driveline than a radial and slightly more consistent.
Kurgan
3,028
Palm Beach Gardens, FL
Oct 4, 2006
  • Oct 4, 2006
Naturally aspirated
275/50R15 drag radial
26x8"-15 Slick
Power Adder
275/50R15 drag radial - 3.73 or lower ratio gears
275/60R15 drag radial - 4.10 or higher ratio gears
26x10.5"-15 Slick - 3.73 or lower ratio gears
28x10.5"-15 Slick - 4.10 or higher ratio gears
If this is a daily driver, you'll probably want to stick with the 26" tall drag radials on the street (275/50R15) unless you really want the look of the 28" drag radials on the street... but with a power adder and 4.10+ ratio gears and a 26" tire you'll run out of gear in 4th gear on the track if you're going to be trapping 113+ mph with the stock rev limiter.
E
Red Theft Light stuck on when parked only
  • Eightiesrock1980
  • Sunday at 3:40 PM
1996 - 2004 SN95 Mustang -General/Talk- Sunday at 3:41 PM
Eightiesrock1980
E
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
Wheel backspacing
  • Brad Hanks
  • Sep 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2025
Brad Hanks
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
