i went to summit and bought a trick flow track heat intake, with plenioum spacer, 24 lb injectors, granatelli mass air for 24 lb injectors, and crane roller rockers.
i installed everthing, and now he car is really slow.
and idels spiraticly at startup, and i have ton rev it or it will die.
i had to take out the distributor, and i just puled it out, and lined it up.
i hear this ticking sound, like i did before i put in the rockers, but it may be louder now.
what should my timing be set at?
what do you think is wrong?
would having the distributor 1 tooth off, make me loose 100hp?
i tightened the roller rockers to 25 ft lbs, two at a time when they were compressed
