18" tire Recommendation
  • Thread starter Thread starter bobc83
  • Start date Start date Jun 17, 2008
bobc83
130
Normal,IL
Jun 17, 2008
  • Jun 17, 2008
What 18" tires sizes are you guys running to give a little more sidewall. I have 18x9" DD bullits with 265/35's on all four corners. It looks great but looks like I can stick a bit more tire in the rear. They kinda look skinny too, the front not so bad but maybe I could shoot for a 255/40 up front and a 275/40 in the rear? If anyone has some advice or pics I would greatly appreciate it.
StangYellow
1,052
Jun 17, 2008
  • Jun 17, 2008
* i dont know what happened there
I believe 275/30's are the widest you can fit on a 9inch wheel
bobc83
130
Normal,IL
Jun 17, 2008
  • Jun 17, 2008
lol np
mustang50v8
548
847 Chicago Burbs
Jun 17, 2008
  • Jun 17, 2008
i have 275/35/18 on my 18x9 fr500 front wheels. 275/40 would be way too much sidewall.
isjoining
143
Orlando, FL
Jun 17, 2008
  • Jun 17, 2008
275/35 will be closest to stock diameter size.
M
MikeCruizin
Premium Sponsor
Jun 3, 2008
99
  • Jun 17, 2008
One thing you must keep in mind if running staggered Deep Dish Bullitt Wheels and tires you don't want to run the same profile in the front and rear. The only exception would be sizes that are extremely close together regarding width, which generally isn't the case.
If you are running standard staggered drag look with 18X9 & 18X10 Bullitt wheels you might consider a 255/40ZR/18 in the front and a 285/35/18 in the rear. This is a very common setup for performance Mustangs.
If you are looking for performance but want to save some money, keep in mind tire sizes will be a factor. In that case I would recommend a 245/40ZR/18 in the front and a 275/35ZR/18 in the rear. The reason I stagger the tires in this manner is because both of these tire combinations have almost identical diameters in both the front and back. Thus, your car will sit respectfully level so to speak, rather than be sitting like a slight wedge one way or the other. This is not generally the look folks are going for but if it is you would want to be taller in the front and not the back for the best look.
Now if you are running the same size rim in both the front and rear I would recommend going up to a 275 series as some here have suggested. 18X9 Bullitt wheels fit very well with a 275/35ZR/18 in both the front and back. This tire is very close to your oem 26" tire diameter as well. I think its just a little short, but all-in-all its very close. The 2003-2004 Cobra run 275 series tires all the way around on 9" rims, so its a great performance set up and you will be able to rotate your tires front to back for extended tread life...
Visit us online: http://www.cruizinconceptswholesale.com
Visit us online: http://www.cruizinconcepts.com
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
