1806 Edelbrock Issues
I had an air cleaner melt (the triangle foam sort.... never doing that again) and I decided to take my carb off and give it a good cleaning. It's a 1806 Edelbrock and I changed no settings and only replaced the 2 major gaskets and cleaned out the melted air filter. I then put it back on turned the key and..... continued to turn it... it wont start. Engine turns and fuel is going in. Any ideas? It could be something simple im typically a body guy and trying the under hood thing pretty much first time.
did you reconnect the choke lead? if not that can be part of your problem. how do you know you are getting fuel through the carb? did you watch the accelerator pump pump fuel into the engine? did you touch the idle mixture screws?
