190cc procomp heads
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Sep 23, 2009
1 of 2 Next Last
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
  • Sep 23, 2009
now im not the person who likes to go cheap if i can avoid it, but after looking at flow numbers versus the price how would these procomp heads compare to the AFR 185's http://cgi.ebay.com/ebaymotors/289-...ads-190cc_W0QQitemZ370261405631QQcmdZViewItem
they seem to have pretty similar flow numbers for a much much cheaper price, they are local to me and i have seen these heads first hand and the quality is quite impressive, im thinking with a few hundred in head work and increasing the combusting size to 72cc for my engine will put me waay ahead of the game and help me finish my Si-trim engine, looking to make 700-800rwhp, so if these heads wont do it i wont bother, but that doesnt mean they cant i just want suggestions
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 23, 2009
  • Sep 23, 2009
i'd put at least a 205cc head with those power goals, 225's wouldnt hurt either
and those flow numbers arent that impressive
trick flow 205's
http://static.trickflow.com/global/images/chartsguides/t/tfs_af_twisted_wedge_s_ss_cnc_205cc.pdf
trick flow 185's
http://static.trickflow.com/global/images/chartsguides/t/tfs_af_twisted_wedge_s_ss_cnc_185cc.pdf
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
  • Sep 23, 2009
Posted via Mobile Device
How many heads have you seen to compare them to? Decent heads. All kinds of things that the eye fails to notice, because it not on plain view, or it doesn't know what its looking at.
I've seen two sets of these heads. Both assembled and took apart. Granted I'm no expert, but the ones I've seen, had valves that were different heights, rocker studs not in line. Things that make setting up the valve train a PITA.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
  • Sep 23, 2009
trick flow 205's
trick flow 185's
i know that larger intake runners are gonna help with power but this is also a road course car so i want to keep the torque curve as low in the rpms and possible
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 23, 2009
  • Sep 23, 2009
this has already been gone over in previous threads, but what your doing isnt going to work, blower(centrifugal) cars are very lazy under 4000rpms, you cant have a car thats gonna be snappy down low and still make 700 hp, unless you have some serious cubes backing it up.
Edit: its a false belief that with a 205cc head you will have no torque down low... look at the dyno sheet in my progress thread and tell me that im giving up torque on the low end
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
  • Sep 23, 2009
im not saying they are awesome but for the price of 500 picked up locally, for 252cfm intake compared to afr's intake cfm of 287, for the price of 2200, big price difference not a big flow difference, and im not assembling these heads my engine builder is and he has worked with procomp heads a number of times and has assured me they are good heads
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
  • Sep 23, 2009
OooKay.
Flow numbers dont mean everything. Its just a small part of the equation.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
  • Sep 23, 2009
im not saying you wont have low torque im just saying generally i'll make lower torque with the 185's
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
  • Sep 23, 2009
liljoe07 said:
OooKay.
yes but its generally the largest part of the equation
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#10
  • Sep 23, 2009
  • #10
There are heads that flow less, but perform better.
You can hog a head out till it flows ridiculous numbers on a Flow Bench. But it has no bearing on how a head performs on an Engine. Heads are tested under 28" of water, and Engine doesnt operate at 28". Not to mention the various pressure drops and rises an engine goes though.
Port Shape, Port Taper, Valve Angle and Placement, MCSA, thats where its at. Flow numbers are just a result, and can be manipulated many ways.
Good Luck on your Pro Comps.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
#11
  • Sep 23, 2009
  • #11
i never said i was going going with procomps, im just saying thats one of the options, currently im still set on AFR's but was wondering if those procomps would be a viable option with my engine, everything is up in the air right now as far as heads go, im sure of the intake and whatnot but still deciding on heads, because well they are the next most expensive thing, 185'2 or 205's trick flow or afr, all this is for research and is in no way me defending any brand, obviously the heads can perform since MM&FF just did a test of their 210cc heads, and obviously AFR's always make great numbers but i simply had a question, and all i got were comments of, procomp is crap, they look good but are crap, and havnt really gotten any background as to why anyone says this
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 23, 2009
#12
  • Sep 23, 2009
  • #12
They look good, on the outside. But there has been many issues with these heads. Some are stated in my first post. With out actually paying attention, and looking for it, you would never notice it. Just trying to help.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 23, 2009
#13
  • Sep 23, 2009
  • #13
i appreciate all help. i looked at the heads pretty closely but i'll go back tomorrow and bring my digital cailper with me for a closer look
white 89 GT
281
Tacoma
Sep 23, 2009
#14
  • Sep 23, 2009
  • #14
If you go cheap don`t expect too much. retainers, springs, keepers, and valves are most likely "cheap" also.
Only one way to make good power and it aint the cheap way.
57fairlane
560
Oakwood, GA
Sep 23, 2009
#15
  • Sep 23, 2009
  • #15
the only way I see them being worth it is if you work at/own a machine shop
1987stangman
684
24
#16
  • Sep 23, 2009
  • #16
Are you a MMFF reader? Check out the lastest issue on their article on 1,000 dollar 400HP 302 build up. Pretty interesting. They used a set of Pro Comp 210CC heads. Not what your looking at but a good read none the less.
I
irish
168
Florida
Sep 23, 2009
#17
  • Sep 23, 2009
  • #17
Usually you have to spend so much to make them right, that you would have saved money and goten better performance simply buying the right head in the first place.
They are copies, bad copies at that.
Matt
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Sep 23, 2009
#18
  • Sep 23, 2009
  • #18
Matt
Exactly.
Machine shop work and parts really start to add up.
Economize by just buying a better head to begin with.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 24, 2009
#19
  • Sep 24, 2009
  • #19
my friend owns a machine shop and i own various tools you would find in a machine shop (lathe, 5 axis mill, presses etc) but im still set on AFR's so far just seeing what other would have to say as the procomps being a viable option
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Sep 24, 2009
#20
  • Sep 24, 2009
  • #20
everytime ive tried to save money, i have to replace the cheap part with the one i was originally considering buying
1 of 2 Next Last
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Afr heads on sale???
  • nickyb
  • Jul 18, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 24, 2022
junkyardwarrior
J
Head Help Trickflow 190cc
  • ebowie
  • Dec 31, 2018
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 1, 2019
ebowie
T
Forced Induction Vortech Pulley Question (Long Read)
  • tinker451
  • Feb 23, 2020
2K
Fox 5.0 Mustang Tech Feb 23, 2020
tinker451
T
