I have just got my dyno numbers back for my 95 stang today and found they are very low! Even the tuner said tey should be higher with my set up,but not sure why they are not. It was pushing 190wrhp which is about 20 more hp then a stock 5.0 my set up is gt40 heads, trickflow street intake, tfs stage 1 cam, 75mm throttle body, 30lb injectors, 76mm mass air, full exhaust w/ long tubers and flowmasters, forged rods and pistons, 7qt oil pan, main girdle and windag tray, aluminum under drive pulleys, ac and egr eliminated. The car is also a 5 speed! Is there something not adding up in my set up? he said that the cam could be to small for the mods but would that be making me lose about 80wrhp? also there is a small vibration as listed in another form but the clutch gets fully engaged and there is no slipping. The tune is set right on the timing is right and the A/F is spot on and the car idles and drives strong without studder. someone please help me find the missing power!
