- May 24, 2006
- 0
- 0
- 0
You are looking at a 1965 Poppy Red Mustang C-Code Coupe with 65,000 original miles. The car was built May 06, 1965 in Dearborn, MI. I purchased the car 4 years ago from the 2nd owner in Pittsburgh, PA with the original 2V 289 for $9,000.00. I pulled the engine and had it professionally built by Gardner Racing Engines to a 347 stroker engine, using the original 1965 289 C-Code block so the numbers match. The cost of the engine block work alone was $6,192.00 which only includes the block, the heads and the internal components. Over $8,000.00 is invested in the engine alone! The car has never been raced or driven hard, only used for local car shows or cruises, never driven in rain, and stored from November to March. Please do not buy on this car if you are not planning on abusing it, I want to see this car go to a good home and see someone enjoy it! If you have any questions please contact me at [email protected]!!
Year/Make/Model:
-1965 Mustang C-Code Coupe
Door Plate Codes: 65A 3 26 06S 53 6 5
VIN Number: 5F07C717585
Body/Paint:
- Poppy Red Lacquer paint (Original 1965 Factory Color)
Engine:
- Original 1965 Ford 289 C-Code block with 347 Stroker Kit
- 9.8-1 compression
- 347 crankshaft
- CompCams Polished Pushrods
- CompCams hydraulic lifters
- CompCams Roller Rockers
- ARP 90,000lbs. Rocker Studs
- Manley Stainless intake and exhaust valves
- Xtreme Energy CompCams hydraulic roller camshaft
- CompCams double Roller timing chain-gears
- Keith Black Racing Pistons
- H-Beam Connecting Rods
- Clevite bearings
- Melling high performance oil pump
- Felpro Hi-Temp Gaskets
- World Products Windsor heads
- Edelbrock AIR-GAP RPM aluminum intake
- Ford Motorsport valve covers & air cleaner
- Autolite distributor with Taylor wires
- Holley Dominator mechanical fuel pump
- Holley 750 C.F.M. carb with Manual choke
- ARP Stainless engine bolt kit
- Custom made 3 Chamber Radiator
- High speed Flex-a-Lite fan
Estimated Horsepower: 400HP
Headers/Exhaust:
- Hooker Super Comp long tube headers
- Custom 2 ½" Aluminized H-pipe
- 2 Chamber 40 Series Flowmaster Mufflers
- 2 ½" Custom Chrome Mandrel Bent tailpipes
Trans/Rear:
- Ford 8" Posi-Traction Rear End
- Richmond 4.11 Gears
- 28 Spline 5 lug axles
- 4 Speed Manual Transmission
- Heavy Duty 10 ½" Ram Racing Clutch
Brakes/Suspension:
- Gabriel Sensa-Trac Front Shocks
- Gabriel Rear Hi-Jacker Air Shocks (200 PSI MAX)
- Mustang front and rear drum brakes
Wheels/Tires:
- 14x7 Magnum 500 Mustang rims
- BFGoodrich 215/70/14 Radial T/A tires
Interior/Audio:
- NEW! Black Vinyl Seats
- NEW! Black Loop Carpet
- Autometer 10,000 RPM Tach
- Dual Gauge cluster (Oil pressure - Water Temp)
- Original 1965 AM Radio (Still Works)
- Original 1965 Factory FOMOCO Speakers (Still Work)
Price: $11,900.00 or make me an offer.. All reasonable offers will be considered!!
Pictures can be found at: http://community.webshots.com/album/550574683KQsvoA
amnit:
