Hello, should I disconnect my clock as my battery seems to drain while sitting a few weeks, My battery may not be the best but just checking if it will help to remove clock from issue? Thanks Rick.
Clocks normally don't draw that much current.
Try hooking up and ammeter in line with the battery with the car off and watch the ammeter as you pull each fuse.
Mongo, you're still alive. Rick, put a battery switch on it if you're not using it much. And if that doesn't cure it you know the battery is NG. And a battery switch is never a bad idea. Oh, did you check the water in the cells? Just a thought.
Here is a method to find a short by an old hand at it- Woodchuck on VMF:
How to find a short
Disconnect the negative battery cable from the battery and place a test light between the post (I like to hold the test light "probe" to the post with a hose clamp, and clip the alligator clip to the end of the battery ground cable. Make sure the doors are shut and the key is "off".
If you have a glowing test light you have a drain somewhere. Start by disconnecting the voltage regulator. If the light goes off you have either a shorted alternator brush or bad regulator. If the alternator warning lamp goes off the minute the engine starts it's probably NOT the alternator but the regulator.
If the test light stays on, reach inside and open the glovebox door, remove the glovebox light bulb and check the test light. If it goes out, replace the glovebox light switch.
Test light still on? Reach in the other side through the window with the door closed and pull up on the brake pedal. If the test light goes off, adjust or replace the brake light switch.
Those are the most common.
The next test would be to tape down the door courtesy light door jamb switch and, one by one, pull a fuse and see if it makes the light go out. If so, check the items on that particular circuit. If you STILL can't make the light go out, pull the plug on the ignition switch. Other than those, it's tracing the non-circuit-protected "hot" wires.
