Hi, new member to this board.
I have a problem with my 66 289 mustang that has been sitting for several years;
No matter what I do, I can't get the car to drive forward.
Reverse engages and works GREAT.
What I've done so far:
-flush the tranny with fresh oil a few times
-used TransX additive that's supposed to free up stuck parts etc.
-flushed again a couple of times.
-overfilled the tranny in an attempt to force oil everywhere it needs to go
-removed excess oil and tried with correct amount of oil
-adjusted the Intermediate band as per the instructions in my Haynes manual:
10lbs ft, then backed the screw out 1 3/4 turns.
-tightened the screw again gradually (virtually no effect)
I have NOT tried to adjust the low/reverse band, mainly because the reverse works ok. Should I?
Big question here is, which band is being used when you start driving from standing still? I notice no difference between the two Drive positions and the Low shifter position. In Low it may creep forward even slower than in Drive, but that would be more or less standing still then.
I do not have a kickdown cable installed. It should not effect the transmission like this but I will get one asap.
I can get the car to slowly creep forward if there's absolutely no incline, and sometimes if I rev the engine REALLY high, it suddenly engages, burns rubber, and the car accelerates ok until I let off the gas. Then it disengages again, and usually won't get going again at all.
Any help welcome.
Jan Andersson
Altamonte Springs, FL
Any help welcome.
Jan Andersson
. It doesn't lock up, you have now forward gears. If you have always done it yourself, don't let this be any different. Buy a book, or video. I went for the video. I've redone mine twice now. Once when it went out the first time, and then 3.5 years later after beating it up the whole time. If you keep it stock, you could do it under 100 bucks. You need a pair of snap ring pliers, and the other part I paid a tranny shop to put a spring in.
