1966 mustang 289 Balance mystery
Wardy
Delaware
I have a 1966 mustang with a 289 and a balance issue. i have replaced the motor with engine code (05AE 6015E) i believe this motor is from a 64-65 Comet or Galaxy . So here is where it gets confusing, i am know i used the harmonic balancer from the 66 and put it onto the 64 motor. Since the i purchased a new harmonic balancer thinking that would solve the problem.. no it did not. Now i have moved to the flywheel. I believe i have a 50oz flywheel. To try to solve this mystery i have removed the trans and i intend on starting the car without the flywheel to see if i need to purchase a 0 balance flywheel. Is there a way i can determine what harmonic ballad and flywheel go with this crank without tearing the entire motor apart? Please help!
FYI.. I created this problem when i was 18, now here i am at 50 trying to fix it..lol
Wardy
  • Sponsors(?)
dennis112
1,515
28
79
Amish Wonderland of Central PA.
Um ...how will you start the motor with out a fly wheel ?
Valid point . . . . .
Since it was not mentioned, all small block Fords from their introduction in the early 60's until about 1981 have a 28oz imbalance. From then on the 351w retained the 28 ounce but the 303 went to 50oz imbalance. From then on the 351w retained the 28 ounce but the 302 went to 50oz imbalance. None ever came with 0 balance from the factory (which is a performance mod). I suggest finding the block casting # to help narrow down the year of the block or pulling the oil pan to get the casting # off the crank (preferred.)
Here's an idea--if you remove the flywheel, look to see if you can prominately see the motor's rear main seal. If can see it it is more than likely a 1 piece seal used from 1981 and newer (50oz imbalance.) If you can only see the rear main cap it is the older 28oz design crank.
One final note is that both the balancer and the flywheel must match in imbalance and any other combos will not work smoothly. The matched pair must also match the imbalance of the crank being used.
There is a little more involved concerning crank interchange and aftermarket cranks but I'd first verify the info above before spending more money.
Wardy
Delaware
Dennis, Thank you for your response. I am fully aware you cannot start the car without the flywheel. My intent was to figure out what I have in interchange the flywheel to see what one removes the vibration. This is the most expensive path.
Next question: is the flex plate and the Harmonic balance labeled to indicate the weight?
Thanks
2Blue2
will be trying this sex one when I can find it
Mar 5, 2019
1,764
1,003
123
52
Oahu
Since you have had this combo for 32 years (since 87 or so) and I assume it was used then.
C6Ae block most likely will need 28 imbalance damper and flex plate
dennis112
1,515
28
79
Thanks
There are no stampings used that would indicate weight.
If you can find a casting # it might help to identify the year. Front and rear photos may be compared to those found on the web. If you are going to buy parts and you are sure you have a 289, get them for 28oz imbalance.
Are you sure the motor doesn't have a miss instead?
Wardy
Delaware
Dennis, thanks agin for you response. This is what i learned today.
Casting # C5AE 6015E this is a 289 for a 1965 Ford Galaxie.
Date code is # 4K24 this was manufactured on October 2nd in 1964.
1. I have removed the flex plate, it is a 157 tooth that measures 13 and 1/4". this is for the small bell housing of the C4 trans. The flex plate has no part numbers at all. I still do not know if this is a 28 or 50 OZ plate.
2. I inspected the rear end of the crank, no part numbers.
3. The harmonic Balancer had part # 594-269. i font this online to be a direct replacement for stock 289 -1966 Mustang and the 1964 Galixie but the weight spec was not shown online.
Do you think it is safe to say my 1964-289 requires a 28 oz flywheel?
any help is appreciated.
Thanks
Wardy
2Blue2
Mar 5, 2019
1,764
1,003
123
52
Oahu
It is safe to say a 289 needs a 28 0z flywheel or flex plate and harmonic balancer, Disclaimer~ unless the crank was swapped for a 5.0 crank (which is doubtful but not impossible)
Post a pic of your mustang, We all live for mustang pics here.
dennis112
1,515
28
79
Yes it should be 28oz imbalance.
I doubt that the crank has been swapped out for a newer 5.0 as it (the 5.0) is designed to use a 1 piece crank seal. I don't think one can be used in the early block that you have.
Thread starter Similar threads Forum Replies Date
S Thermal clutch fan recommendations for 1966 Mustang w/ 289 1965 - 1973 Classic Mustangs -General/Talk- 1
B 1966 289 Mustang Overheating 1965 - 1973 Classic Mustangs -General/Talk- 8
H 1966 Mustang 289 flywheel info needed Classic Mustang Specific Tech 7
D 1966 Mustang 2bbl, 289, C4 disk brake conversion Classic Mustang Specific Tech 3
S New Member - Spark Plug Question (289) 1965 - 1973 Classic Mustangs -General/Talk- 5
R Mild 289 Build For 1966 Mustang Coupe Engine and Power Adder 4
199 1966 Mustang 289 Hot weather Engine Oil Advise & Suggestions Classic Mustang Specific Tech 4
R 1966 Mustang 289 missing timing indicator Classic Mustang Specific Tech 2
G 1966 Mustang Coupe 289... Project + LOTS OF PARTS Engine and Power Adder 0
D 1966 mustang coupe 289 "C" code matching numbers trade for? Classic Mustang Specific Tech 0
H over heating on 1966 mustang Classic Mustang Specific Tech 7
R 1966 Mustang Coupe Wiring 1965 - 1973 Classic Mustangs -General/Talk- 2
R 1966 Mustang Brake Issues 1965 - 1973 Classic Mustangs -General/Talk- 9
R 1966 Coupe Radio Wiring 1965 - 1973 Classic Mustangs -General/Talk- 0
N Need Help With 1966 Mustang Heater Problem Classic Mustang Specific Tech 8
6 Biggest rear tire stock height 1966 Mustang??? 1965 - 1973 Classic Mustangs -General/Talk- 0
M Will a Mustang radio made for a 1964 - 1966 Mustang Stereo 1965 - 1973 Classic Mustangs -General/Talk- 7
wicked93gs 1966 Mustang Coupe: Ford 3.7L swap 1965 - 1973 Classic Mustangs -General/Talk- 10
Z building a 1966 mustang straight 6 200ci on a budget Classic Mustang Specific Tech 3
wicked93gs Swapping a 3.7L v6 into my 1966 Mustang, looking for a bit of ECU info 2005 - 2014 Specific V6 Tech 10
S WTB/Trade Need AC unit for 1966 Mustang convertible Interior Exterior Parts 0
N 1966 mustang rear axle 1965 - 1973 Classic Mustangs -General/Talk- 2
R My new 66 mustang 1965 - 1973 Classic Mustangs -General/Talk- 5
K For Sale Translucent Red 1966 Ford Mustang GT350 For Sale! Classic Mustangs For Sale 0
R For Sale Classic 1965GT 1966 Mustang gauges Interior Exterior Parts 0
S 1966 Mustang thermactor filter 1965 - 1973 Classic Mustangs -General/Talk- 4
E mustang 1966 Oil in intake Classic Mustang Specific Tech 7
F 1966 mustang buck tag info 1965 - 1973 Classic Mustangs -General/Talk- 0
A 1966 Mustang Help 1965 - 1973 Classic Mustangs -General/Talk- 1
S 1966 mustang 1965 - 1973 Classic Mustangs -General/Talk- 1
A 1966 Mustang - Can anyone tell me what engine this is? 1965 - 1973 Classic Mustangs -General/Talk- 4
WadeMcBeth Spindle change between 1966 and 1970 Mustang 1965 - 1973 Classic Mustangs -General/Talk- 5
L 1966 mustang 1965 - 1973 Classic Mustangs -General/Talk- 3
M 1966 Mustang GT Tires and Wheels HELP 1965 - 1973 Classic Mustangs -General/Talk- 2
codecraig Drop-In Engine Suggestions for 66 Coupe 1965 - 1973 Classic Mustangs -General/Talk- 3
MoDriver SOLD 1965-1966 & 1969-1970 Ford Mustang Exterior Door Handle Kit Interior Exterior Parts 0
3ohh2 1966 Mustang Front Wheel Bearing wobble Classic Mustang Specific Tech 6
C 1969 mustang hood The Welcome Wagon 2
M 1966 Mustang Coupe With 302 Engine Classic Mustang Specific Tech 6
D 1966 Mustang 427 Afx Restoration 1965 - 1973 Classic Mustangs -General/Talk- 5
T 1966 Mustang Wheel Tire And Aligment Issue Classic Mustang Specific Tech 2
MoDriver SOLD 1964.5-1966 Ford Mustang Quarter Panels - Original From Ford Parts Dept. (Virginia - 22152) Interior Exterior Parts 0
T Expired 1966 Mustang Gt Project [calif. Bay Area] Classic Mustangs For Sale 0
Tubbster66 SOLD 1966 Mustang Coupe - Fuel Injected Classic Mustangs For Sale 2
J 1966 Mustang Title 1965 - 1973 Classic Mustangs -General/Talk- 4
1 1966 Mustang Rim Fitment 1965 - 1973 Classic Mustangs -General/Talk- 4
MoDriver For Sale 1964-1966 Ford Mustang Coupe Quarter Panels - Original Ford Parts (springfield, Va) Interior Exterior Parts 0
K 1966 Mustang Wheels Classic Mustang Specific Tech 3
D SOLD 1966 Mustang Coupe Classic Mustangs For Sale 1
M Expired 2014 F150 Coyote Engine Other Classifieds 0
