1967 Mustang Rims
  • Thread starter Thread starter kbelusa
  • Start date Start date Aug 7, 2007
K
kbelusa
Toronto, Canada
Aug 7, 2007
  • Aug 7, 2007
Hello everyone.
I have a 1967 Mustang that I am trying to fit as wide a tire into as is possible. Can anyone tell me what is the largest tire is that I can install stock with the lip of the quarter panel "rolled"? How much back spacing?
If possible I would love to install a 10" rim, but I understand that the largest possible without cutting the wheels is an 8". Does anyone know what needs to be done to install this larger wheel? There is a 1-1.5" space between the inner wheel well (wheel well in trunk) to the frame rail and I was thinking of cutting this to fit the tire.
65intex
85
Ft. Worth, Texas
Aug 7, 2007
  • Aug 7, 2007
http://www.dodgestang.com/Tire Fitment Guide 67-8.pdf
E
EricButler
9
  • Aug 8, 2007
I am running a 17x9.5 with 6" backspace. If you have drum brakes in the rear then that is too much backspacing and it will rub a little on the inner wheel well on a turn if you have the car lowered like I do. But if you have disc brakes in the rear then it is perfect and you won't have to run spacers. You can put a 285/40/17 on a 9.5" rim.
G
grego37
576
Fresno CA
Aug 8, 2007
  • Aug 8, 2007
ditto.
285 width with a 9 - 9.5" width with the correct backspace is pretty much the max. without having rubbing issues.
keep the tire bead no closer than 1/2" away from its first inner contact (the leaf spring) and roll the fender lip on the outter side
K
kbelusa
Toronto, Canada
Aug 10, 2007
  • Aug 10, 2007
OOOPPS I left a little out
Sorry, but I think I left out a little bit of information. Novice mistake.
The car has 1 piston Bear brakes in the rear mated to a TCP rear coil over. Not the new coil over, but the original coil over with the "cage” around the axel. Link below.
http://www.totalcontrolproducts.com/rearcoil.html
Is that 9-9.5" maximum tire size with the wheel well modified or with a stock wheel well?
E
EricButler
9
  • Aug 10, 2007
Stock wheel well.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 6:30 PM
AeroCoupe
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Saturday at 8:07 PM
Fox 5.0 Mustang Tech Monday at 2:02 PM
Jakub2537
J
