1967 s-code fan problem
michalm
Hi, i have some issues with my fan. I noticed fluid leaking under my car and when I looked under the hood it turned out that the propeller had damaged the radiator. what could be the reason? Fan clutch malfunction? To much rpm?
  • Sponsors(?)
1320stang
4,268
53
Edmond, Oklahoma
community.webshots.com
Is the radiator leaking or did the fan just bend some fins over? Grab the fan and see if there's any play in the fan clutch, or possibly the water pump shaft. (Could be the water pump is bad, leaking and shaft play caused the fan to hit the radiator.)
Thread starter Similar threads Forum Replies Date
C For Sale 1967 289 K Code For Sale Engine and Power Adder 2
M Expired 1967 S Code 390 Gt Air Cleaner Engine and Power Adder 0
K 1967 Stang Code S 4spd 1965 - 1973 Classic Mustangs -General/Talk- 0
K Barn Find 1967 S-code SN95 4.6L Mustang Tech 0
P 1967 Mustang C Code Coupe Value 1965 - 1973 Classic Mustangs -General/Talk- 6
A SOLD 1967 Mustang Gta Coupe, S-code Classic Mustangs For Sale 5
JohnnyK81 Code 66. 1967 With 87 Harness And Maf Fox 5.0 Mustang Tech 24
B 1967 Fastback 4 Speed "a" Code ___ So - Cal Classic Mustangs For Sale 0
B 1967 Fastback ... "S" code GT ... 4 Speed Classic Mustangs For Sale 1
66fstbk is an A-Code 1967 a gt? Classic Mustang Specific Tech 9
spfd 1967 Blue - standard bucket, vinyl - Code 2B Classic Mustang Specific Tech 2
M 1967 Mustang Coupe original 390 S Code Classic Mustangs For Sale 0
1 1967 Axle Code Help -- "0"?!? Classic Mustang Specific Tech 5
S 1967 C code fastback sadly for sale Classic Mustangs For Sale 7
B 1967 coupe, c code, restored, black plates,289,c4,all power Engine and Power Adder 0
9 1967 Mustang S Code 4 Speed Eleanor 428 Classic Mustang Specific Tech 14
TwinTurboV8 1967 inline-6 Ford Mustang single barrel carb to double barrel carb 1965 - 1973 Classic Mustangs -General/Talk- 1
R water pump replacement issues on 1967 200ci 1965 - 1973 Classic Mustangs -General/Talk- 3
T Hello Mustang Lovers! Long time reader, first time member. I have a 1967 Mustang coupe with a 200 CID engine. The Welcome Wagon 0
N 1967 Max Air Conditioning blows out of floor vents 1965 - 1973 Classic Mustangs -General/Talk- 3
D 1967 Ford 8" Axle 1965 - 1973 Classic Mustangs -General/Talk- 3
E 1967 transmission dylema 1965 - 1973 Classic Mustangs -General/Talk- 4
derek2079 For Sale 1967 Mustang Radiator Original Engine and Power Adder 0
W 1967 dynacorn frame rail and shock tower assembly issue 1965 - 1973 Classic Mustangs -General/Talk- 2
C Interior swap for 1967 mustang 1965 - 1973 Classic Mustangs -General/Talk- 2
A 1967 Mustang decoding Buck plate The Welcome Wagon 3
A Engine Need Help Finding a Part Classic Mustang Specific Tech 2
G 1967 Fastback GTA, Gabriel Hi Jackers Rub 1965 - 1973 Classic Mustangs -General/Talk- 1
derek2079 SOLD 1967 Mustang Radiator OEM Classic Mustangs For Sale 1
D 1967 mustang 289 V8 headers 1965 - 1973 Classic Mustangs -General/Talk- 2
T 1974 F-100 9" in a 1967 Mustang coupe 1965 - 1973 Classic Mustangs -General/Talk- 1
derek2079 For Sale 1967-1968 Shelby Tail Light Bezels. Interior Exterior Parts 0
G Recommendations for a Disk Brake Kit for my 1967. 1965 - 1973 Classic Mustangs -General/Talk- 2
P 1995 5.0 t-5 swap into 1967 coupe The Welcome Wagon 4
C 1967 coupe The Welcome Wagon 1
J Engine 302 Roller Build Fox Engine Swaparoo 2
T 1967 Mustang Coupe 5-speed swap 1965 - 1973 Classic Mustangs -General/Talk- 13
Mattster_ '67 Mustang 289 Cooling issue. 1965 - 1973 Classic Mustangs -General/Talk- 3
W Question on a grille for a 1967 Stang 1965 - 1973 Classic Mustangs -General/Talk- 1
M 1967 Mustang Coupe - 17" Wheel backspacing 1965 - 1973 Classic Mustangs -General/Talk- 0
G 1967 Mustang Brake Light Problem 1965 - 1973 Classic Mustangs -General/Talk- 8
6 1967 GT emblem location (template/measurements) Classic Mustang Specific Tech 0
B Progress Thread 1967 Coupe Restomod 1965 - 1973 Classic Mustangs -General/Talk- 3
K Interior and Upholstery 1967 fastback 3-point harness in the REAR. Need advice. 1965 - 1973 Classic Mustangs -General/Talk- 2
K What's it Worth? Seeking rough valuation on manual 1967 Coupe w/ 351 Windsor What is it Worth?!?!? 2
7 New member from MS, 1967 Fastback The Welcome Wagon 3
P 1967 Specific Wheel Question 1965 - 1973 Classic Mustangs -General/Talk- 4
Mustang Gregg 1967 I need 289 engine serial number location Classic Mustang Specific Tech 2
J Wheels-Tires 1967 coupe with 8.8 inch rear end Classic Mustang Specific Tech 0
H unusual Barn find 1967 coupe 1965 - 1973 Classic Mustangs -General/Talk- 5
