reenmachine
20+ Year Stangneter
OK, I'll chime in having done the mod motor swap. This has been posted above and I have said it before, but I will repeat it again:
Even with the "free" engine, this will absolutely be a much more expensive and massively more time-consuming swap than purchasing and using a 302/351/whatever pushrod engine.
Physically putting the engine in the car isn't rocket science. A chop chop here and a zap zap there and it's in. And now you've swum to the center of the ocean -- a remarkable feat but really just the beginning!
Getting all of the car's other systems, both mechanical and electrical, to work is the trick. The steering, cooling, heating, suspension, fuel, lubrication, and braking systems need extensive modification. Never mind the electrical system -- that's a whole huge project in and of itself.
If you're just trying to put a "pretty" stang together for your gf, you will live to regret trying to swap the Lincoln mod motor in. She will also probably dump you because you will have to devote every bit of your free time for the next year to getting it to run.
I don't mean to sound harsh -- just my .02 from experience.
The lights are on, but nobody's home
