1971-1973 mustang questions?
mfernandez72490
1. Is the 1971-1973 unibody or chassis setup?
2. Does anybody know of any successful air ride setups? if so do you have any pictures? Know wat brand they used and what kit?
Please reply with links if you have any thanks and pictures
They are a unibody.
Have you contacted Air ride technologies to see if they offer a kit? The same upper and lower control arms fit 68' to 73' and the coil spriongs for 67' to 73' are interchangeable. The only difference I can see is the upper shock mount. The Air ride kits replace the coil spring and shock with their airbag. So, if they offer a set up that uses the 71' to 73' upper shock mount then you're covered. If not it should not be to difficult to fab a mount for the top of their set up.
