1971 mach 1 build
I'm building a 71 mach 1 with a 351c i don't know what I should do for more power were should I start when building a engine
Hi,
Can you share more about what you’ve got there, running condition of the motor, trans & if fairly stock or modified- if so, to what extent?
A 71’ 351C 2 or 4 barrel motor? Heads?
What are your power goals?
Not as cheap as a 351W to build, but they respond to bolt-on’s strong & are much more capable & resilient.
Engineering marvels of their time..
Best!
John
Lots of cams that are better than stock and no problem for daily drivers. Is trans a C4 or FMX? Most 351Cs I have seen had FMX's (a variant on a C4).
  • PlusOne
Reactions: 2Blue2
