Expired 1984 Svo
bn536
63
Stuart, Fl
Black hatchback, gray interior, sunroof, Turbo 4, 5 speed. Literally 2 miles on all work: New carpet, Kenwood CD, clean interior. New fuel tank, filler hose and both fuel pumps. New power steering pump, rack & pinion, and I/O tie rod ends. New urethane (all Energy Suspension) coil spring isolators, ball joint covers and sway bar bushings. New plugs, wires, cap, rotor, coil, K&N, coolant, thermostat, silicone coolant lines, and electric fan switch. New front brake lines, I/O wheel bearings. TBird TurboCoupe exhaust manifold with new gasket; new Valve Cover gasket; have a '95 throttle body, but it is not installed. Evergreen Turbo rebuild with larger housing! Rattle can resto on all associated frame/engine/interior work.
Things left to do: 1) I believe head gasket needs replaced (runs good, but antifreeze drops; oil is clean). 2) Throwout bearing is loud. 3) Hatch is rusted and body needs paint. 4) Needs tires (original SVO wheels). 5) Needs new front light housings (all 6 are there, but very yellow), also, this car is setup with flush '85/'86 lights. 6) Original SVO Steering Wheel and Hurst Shift Knob in rough shape.
Clean title. $1900. Located in Stuart, Fl. Email [email protected]
