Progress Thread 1986 Ssp Budget Build
  • Thread starter Thread starter bigo5552000
  • Start date Start date Jan 4, 2015
First Prev 2 of 2
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
Jan 6, 2015
#21
  • Jan 6, 2015
  • #21
Looks like an awesome project welcome and have fun !
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Jan 6, 2015
#22
  • Jan 6, 2015
  • #22
bigo5552000 said:
I have done some pricing. I was thinking gt-40/40p. The local you pull junk yard has several older v8 explores and heads are like $35/per. I am thinking I will get them worked at a shop. Yeah I am trying to do as much research as I can! Yes budget are dream killers, but this is an initial budget! I need to bring it back to life and have something fun to drive quickly; I don't want the project to die in my garage!
You'll get there. $35 a head, cool deal. Not bad man.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 6, 2015
#23
  • Jan 6, 2015
  • #23
A5literMan said:
The gt40's are no good without a spring upgrade and cam change. You can get into the 500$ range including purchase,parts,and machine work. If the engine you purchased doesn't need much you can probably do a rebuild under 1000$ at the cheapest.
$500 still isn't too bad for a freshened set of heads though. Wouldn't that still be cheaper than if he bought a set if used trick flow and the likes? At least the gt40's would be "new" after all the work is done. I'm pretty sure a cam swap was one of the "needs" he had on his shopping list. But the icing on the cake: He could probably beat a Camry
Reactions: Noobz347
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jan 7, 2015
#24
  • Jan 7, 2015
  • #24
For once, I think I agree with 90. $500 ain't nothing compared to the cost either buying new heads or having used aluminum worked over for install. Plus gaskets, plus exhaust, plus intake, cam... *insert snowball gif here*....
There are some pretty potent P head cars out there. Make the damned thing healthy (cheap and reliable) then boost the chit out of it.
Reactions: 90lxwhite
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Jan 7, 2015
#25
  • Jan 7, 2015
  • #25
Noobz347 said:
The pieces and parts will end up totaling more than that in the end. $2k in hand will get you well on your way if you're careful. With luck, $2k will get you rolling. Another $500 on that for incidentals that in your head, don't count because they're small amounts that you pay with what's in your pocket.
If you end up keeping the car then you'll spend another 4 easy on upgrades, power, and insufficient supporting mods.
You will then drop the family fortune on a REAL motor.
After that, you'll move, drive it occasionally and keep it stored (needs an oil and fuel swap by now).
Then when you have the time and cash (at once... like together at the same time) you'll detune it a bit and spend some more cash on those previously mentioned supporting mods.
One day though...
Amen brother!
Yes, you can get it up and running in fine stock condition for 2k then build/beautify from there. First things first though, go through it, open up the engine and see what's what, skip all the engine mods till you have it running, gt40 heads $500, nice used trickflow aluminum $900ish if you look and wait. build the mod parts pile on the side and wait.... odds are if you have a tight budget and are wanting more you'll be selling it to some guy at work for 500 in pieces because you lost interest vs getting it running and enjoyable
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Jan 7, 2015
#26
  • Jan 7, 2015
  • #26
Valve jobs, spring kits and surface decking cost the same for any head really. If you can get a set of gt40's for $70, do it. That's only $70 more than redoing your stock E7's.
See if you can get your block and crank checked, then buy one of the cheaper rebuild kits from.Summit. I still think you will have about a grand in the engine by the time you do fluids and all the misc stuff.
Joe
Reactions: A5literMan
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 7, 2015
#27
  • Jan 7, 2015
  • #27
I'm routing for this guy.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jan 7, 2015
#28
  • Jan 7, 2015
  • #28
He'll need the extra dough for a proper fuel system.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 7, 2015
#29
  • Jan 7, 2015
  • #29
Allegedly... But really though I was thinking if he didn't have or has stock fox tb and maf he could try and find a used 94/95 tb and maf or get a reman 94/95 maf from the parts store for $75
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jan 7, 2015
#30
  • Jan 7, 2015
  • #30
Let's get it running then see where the problem children are.
bigo5552000
15
#31
  • Jan 7, 2015
  • #31
I plan on working the heads and matching them to the cam I select.
I surely hope I can!!
bigo5552000
15
#32
  • Jan 7, 2015
  • #32
So my plans thus far for the engine is worked GT40s, cam, stock forged pistons, and this rebuild kit http://www.summitracing.com/parts/fem-mk6115a-000/overview/year/1988/make/ford/model/mustang .
Also, I wanted to get some feedback from everyone staying EFI or converting to carb. I currently have a new BBK 70mm throttle body and EGR plate along with a ford racing MAF conversion kit. The question is do I stay EFI or do I sell all those parts and go carb and use the money to help finance the build. The reason I even think about carb is if I get a cam, heads, and possibly a small shot of nitrous won't I still need more mods to the EFI?
tca7291
I can see your wieners.
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Jan 7, 2015
#33
  • Jan 7, 2015
  • #33
Go with the EFI... do the MAF conversion. Carburetors are dumb. Do I need to call up JR?
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Jan 8, 2015
#34
  • Jan 8, 2015
  • #34
Stick w efi if you get the gt40 heads all your lacking is an explorer intake and 24# injectors to have a "cobra" motor.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 8, 2015
#35
  • Jan 8, 2015
  • #35
You're going to need a new fuel pump either way. I would stay efi as long as the wiring is still good. If there is a strong likelihood of electrical/wiring issues then I'd go to a carb. With the car sitting for along time and where it was stored, there is always a chance for problems(mice,corrosion,cracked/missing pieces)You'd have to change the fuel regulator,dizzy,linkage,etc for a conversion. There again I hope nitrous,etc isn't being planned for in that 2000$ budget though. Also you state that you have a MAF conversion. Does that include the computer? Or do you just have the MAF and wiring alone?
bigo5552000
15
#36
  • Jan 8, 2015
  • #36
It does include a new computer, maf, and wiring. I am concerned about the wiring since it has been sitting for quite sometime and there is plenty of mouse evidence!
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 8, 2015
#37
  • Jan 8, 2015
  • #37
My vote (which won't be popular) is to convert to carb. Only because of the dubious nature of said wiring and "cheap" nature of this build. I would always prefer efi for most instances but not here. If it was my car(with your parameters) that's what I'd do. Used intake and rebuilt carb can be had for under 4-500$. All the misc "conversion" parts another few hundred. Sell the efi stuff to increase your "budget",rebuild engine,etc and yeah I think it can be done for 2k
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jan 8, 2015
#38
  • Jan 8, 2015
  • #38
It's an option for someone who plans to wrench himself and not able to troubleshoot/repair wiring through the use of a diagram.
If you're capable of these things then stick with the fuel injection. It's sooooooo much easier to continue to modify and build on down the road.
If you keep the car you'll be converting back when you want to do a power adder anyway.
First Prev 2 of 2
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
