For sale is a 1987 Ford Mustang LX 5.0, I will list what the car has, what it needs and the condition of everything. This car only has 97,800 original miles on it.
Engine
MAP to MAF conversion
Edelbrock Performer Heads
Edelbrock Performer Intake Manifold
Lunati Cam 525/525 lift
1.6mm Ford Racing Roller Rockers
30lb Ford Racing Injectors
76mm C&L MAF
75MM Edelbrock Throttle Body & EGR Plate
K&N Filter
MSD Distributor, Coil and Wires
March Underdrive Pulleys
BBK Long Tube Headers
BBK Midpipe
Mac catback exhaust
Holly Fuel Pressure Regulator
Drivetrain
Centerforce Stage 3 clutch
Ford Racing lightened flywheel
Hurst Short Throw Shifter
Ford Racing Aluminum Driveshaft
Steeda firewall clutch adjuster
adjustable clutch cable
Steed Aluminum Clutch Quadrant
Other new things
New Manual steering rack
New Tie Rods
Tires, all 4 are new
Alignment
Sub Frame Connectors
Oil Pan Gasket
Rear Main Seal
Transmission Output Shaft Seal
The interior is in a 7 out of 10 for condition, there are no rips or tears in the seats, but it does have normal wear. The car has power windows, but is a no AC Car. It does not have a radio but does have 4 speakers if you wanted to put one in. It does need a few things as with any car that is 23 years old. One fender is dented and would look better if replaced and the front and rear bumper could a repaint due to a couple small scuffs; it could use an upgraded fuel pump to keep up with the injectors and a professional tune. The car runs and drives fine, it doesn't run as good when its cold because of the cam, and 3rd gear grinds sometimes when its cold but never does after it warms up. The car has emissions good for 2 years in the sate of VA and then will be an antique when those two years are up and will no longer need emissions. Saftey inspection is good until 7/10
Car is located in Centreville VA, Please note car does not have the cowl hood or 1 piece headlights anymore it would not pass saftey inspection it now has a stock Black hood and stock lights and looks really good with it! Asking $4,999 or best reasonable offer.
Engine
76mm C&L MAF
K&N Filter
BBK Midpipe
Mac catback exhaust
Drivetrain
Other new things
New Tie Rods
Alignment
Oil Pan Gasket
Rear Main Seal
