1988gt Electrical System Shot. Need Help.
Bear88gt
Im new to stangnet, ive read these forums for years but now need some direct answers, so i joined, any help is appriciated.
I purchased a 1988 mustang gt rolling chassis about 2 years ago, dropped a stock motor in it a few months ago and have had constant problems with ignition, turn signals, my entire gauge cluster. The man that owned this car before me had no clue what he was doing in the electrical system and destroyed it.
After pulling the entire dash out to get an idea of what was going on with the wiring i found the harness and most of the connectors to be shot.
Currently the car will drive but after i get on the road the car trys to die after shifting into overdrive, then every other gear after that around 2000rpm.
The transmission is a professionally rebuilt AOD with an electronic solenoid for the overdrive with a 2800 stall behind a stock motor (yes i plan on replacing the stall back to stock).
I am financially stuck at the moment and have a lot of money in the chassis of the car, but i need to get this thing drivable.
Given the numerous electrical problems i considered a carburetor conversion since i have a carb and intake already and then rewiring all my lights to aftermarket switches, then installing aftermarket gauges.
Just looking for some advice on the easiest or cheapest way to sort this rats nest out.
If you do a carb conversion and rewire, the resale value will have dropped to salvage value for scrap. I do not advise that for a car that has a good body, transmission and engine.
When the engine shuts off, are you able to restart it immediately?
Does the problem occur only on a warm engine or on warm and cold engine?
The engine doesn't shut off. It just try's to stall. If I keep rpm very low, feather the pedal and don't put a load on the transmission it wont stall. I feel it might be important to mention the coil is good the tiff module is good, the distributor came out of a running fox. But there are a few connectors unplugged under the hood with no where to go. There's also a vacuum deal behind the passenger strut tower that isn't hooked up. I've stopped all the vacuum leaks I could find though.
It might cause some shifting problems, but I don't think that it is related to your problem.
As far as the electrical problems, I have an 89 Mustang wiring diagram set which is identical to the 88 with the exception of some of the computer sensors. PM me your email address and I will send you a complete Ford Factory 89 Mustang electrical diagram set. The zip file is 2.5 MB and is too big to fit through Stangnet's email gateway.
89 Mustang wiring diagrams zip package–
They are in a zip file format to reduce the size of the package. If you don't have Windows 7 or Windows 8, you’ll need WinZip or other Windows archive tool to extract them from the zip file.. See MajorGeeks.Com - MajorGeeks - Download Freeware and Shareware Computer Utilities for a free download.
The diagrams show the location area and the connectors are drawn to the same shape as those in the car.
You will need the Adobe Acrobat viewer which is also a free download – Adobe Acrobat Reader DC Install for all versions - Adobe Reader download - All versions
Check the fuel pressure and dump the computer codes for a start. Plan on replacing the fuel filter and draining the tank of any fuel that has been in it for more than 90 days.
Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect the vacuum line from the fuel pressure regulator. Check it for evidence of fuel present in the line by removing it and blowing air through it. If you find fuel, the fuel pressure regulator has failed. Reinstall the line; leave the fuel pressure regulator end of the vacuum line disconnected. Then cap or plug the open end of the vacuum line and stow it out of the way.
Connect the fuel pressure test gauge to the Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure: you should see 37-41 PSI at idle.
Turn the ignition off; reconnect the vacuum line to the fuel pressure regulator. Then disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
Fuel pump pressure test
Disconnect the larger of the two fuel lines up by the Schrader valve. It is the return line and does not have the Schrader valve on it. Find a piece of rubber fuel hose and clamp it on the return line coming from the regulator. Stick a bolt in the other end of the hose and make sure that all your connections are tight and leak proof as possible. When this powers up, you don't want fuel squirting everywhere. Hook up the fuel pressure test gauge. Turn the ignition switch on and watch for leaks. You may want to use a helper inside the car to cut the switch off quickly if you have a leak. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
Caution!!! You have blocked the return line for the fuel pump! Pressure will rise very quickly past safe levels with a good pump
If the pressure goes up past 55 PSI, the pump is good and the fuel pressure regulator is bad. If the fuel pressure does not hit 55 PSI or more in a few seconds, the pump is bad or you have electrical problems.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus Digital Ford Code Reader (3145) Equus - Digital Ford Code Reader (3145It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $22-$36.[/b]
