1989 GT Possible air/fuel issue
Tim83
47
14
18
Hi folks,
I hope everyone is enjoying the summer. I've been having an intermittent issue with my car and I'm hoping someone can help me figure it out. Under normal driving conditions the car behaves as it should but after some spirited driving, mainly winding it out in the first 3 gears, it exhibits what I can only describe as a lurching in low-mid rpm. The behavior is similar to the low rpm lurching you get with an aftermarket cam. It's almost as if there is a very brief interruption in either air or fuel. When the car exhibits this behavior it also idles high at anywhere from 1000-1250rpm. I ran the codes again and received 91 - lean mixture and the EGR valve code. The sensors and valve were original so I just replaced them but the problem persisted. A subsequent read of the codes also gave me the code for insufficient voltage from the TPS so I replaced that as well. I've also removed and cleaned the mass air meter. At this point I'm still receiving the following codes (key on engine off):
10: I don't believe this is anything to worry about unless I perform the cylinder test
29: Vehicle speed sensor
91: o2 sensor out of range/always lean *sometimes I get this code and sometimes I don't
Does this sound familiar to anyone? Could the VSS sensor be my issue or should I check for something else?
*When I installed the new TPS I was unable to get a read on the voltage. I think my multimeter is no good. I assumed if the TPS code didn't resurface then I'm within the correct parameters for TPS voltage. Am I wrong on this?
*I also bought a fuel pressure gauge and the pressure is normal.
Trickflow HCI
BBK CAI
70mm throttle body
75MM mass air
Thank you in advance!
Check for vacuum leaks, also check the coil for grounding traces, that's where the coil or wire jumps to ground around the top where the boot is, open the hood at night with no light around and see if you have spark jumping out of a boot.
Hey man...I know it's been a few days but I've had similar issues from 2 different mustangs recently. Both of them ended up being the vacuum line that runs from under the intake, down under the distributor, and to the carbon canister solenoid at the right front frame rail. Once you fix the line ( if it's the line ) disconnect the battery negative for a while. Unplug the idle air control valve and start the car up. Adjust the idle screw to between 650 and 750rpm. Cut the car off and plug in the IAC and restart the car.
Thanks, man. I suspect mine may be leaking as well. I’ll keep an eye on it when I do the smoke test.
Reactions: 90sickfox
After chasing this issue for 2 years I finally made some progress. This spring the computer gave me a code 14 (continuous memory) for the PIP so I started with a new TFI module but that didn't resolve the issue, so I installed a new distributor. With the new distributor the issue seems to be resolved and the code has not returned. The problem has always been intermittent, so I need to keep driving it to know for sure. I'm having a new issue and I'm not sure if it's related to this one so I'm going to pose a new thread and start fresh. Thank you to everyone who commented.
Reactions: 90sickfox and limp
