1990 5.0 runs fine when cold but terrible when hot
When I do a cold start, the engine dies, but the 2nd or 3rd time it will idle but rough. As it is warming up, it runs strong until it gets up to operating temp. Then runs terrible--like will I make it home?
I have a new dist., coil, 02 sensors, IAC, relatively new ETC and spark plugs. I have a 21, 41 and 91 code (the 41 and 91 disappeared when I put in the 02s only to reappear). The ECT checks out both at the sensor (full range) and the voltage coming to it (5v). I have done the safety pin check on the EVP connector (4.97v) and at the computer (3.5v). I have not yet done the suction test on the EGR. That is my next step. It seems to me if it were a vacuum leak it would always run bad. Would a bad EGR cause it to run as I have described?
Is there anything I am missing?
vacuum leaks will generally cause the car to run rough at idle and will smooth out as you put more load on the vehicle.
I would start tackling your codes first. 21 is an ect related code so I would double check that your vehicle is getting up to operating temperature and not overheating. You could have a cooling system issue like a bad thermostat, water pump or radiator or the ect and/or the ect circuit is bad.
As for the code 41 and 91 they're probably just indicating your car is running lean and there's nothing wrong with the sensors themselves
Did the distributor come with a new TFI ignition module ? Even so, I would suspect that it's bad or possibly the heat sink grease is missing or lacking and the heat can't be disapated correctly. Ignition problems after warm up is classic for the TFI.
whats this heat sink grease? and how can i tell if my distributor is TFI? i replaced my stock unit with a msd distributor about a year ago trying to solve this same problem, but its still running weak sometimes.
All the 86-95 EFI 5.0 Mustangs use a TFI module.
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
See http://www.veryuseful.com/mustang/tech/engine/images/TFI_5.0_comparison.gif for some more useful TFI Module information.
If your car runs poorly at times, dump the codes.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
My vote would be for the tfi, if you choose to replace it, only use a real ford unit unless you want to do it again in 6 months.
When the engine warms up it heat soaks the tfi, it's why on 94/95's they moved it.
