1990 Broken Exhaust Header Bolt.
Eliasstigile
Hi I just did a head gasket swap and my exhaust header bolt broke. Pulled the head back off and started drilling into the bolt. Then the bit I tried to use to turn the bolt out snapped inside. None of my drill bits are getting through the metal now. Any ideas on how to get it out? Thanks.
Also would having one of the bolts missing creak any exhaust leak problems?
Since the head is already off I vote taking it to a machine shop too. The amount they charge is probably going to be equal to how much you'd need to spend on specialty bits for this DIY job. The machine shop will get it right the first time too. Try not to over tighten your header bolts, they don't need much torque. If the bolts are old then get new ones. Good luck.
