Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • Thread starter Thread starter 5.0LXStanger
  • Start date Start date May 25, 2025
  • Tags Tags
    fuel delivery help needed lean pop rough idle
  • 3
First Prev 3 of 3
General karthief
Mod Dude
Aug 25, 2016
28,099
10,714
213
polk county florida
Jun 19, 2025
#41
  • Jun 19, 2025
  • #41
I don't know about the rest of the clowns here but I'll be here all week...
Will work for COOKIES!!
Reactions: Mcmahst
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Jun 21, 2025
#42
  • Jun 21, 2025
  • #42
You don't need the T-Rex boost pump any more with the 255 lph Walbro in-tank pump. The T-Rex boost pump was only needed to supplement the 88 lph in-tank factory pump. Unless I missed it, are you still using the factory A9L ECU & MAF? Neither are calibrated for 24lb injectors.
Admin Dude
Jan 4, 1985
43,463
21,647
234
Box behind Walmart
Jun 21, 2025
#43
  • Jun 21, 2025
  • #43
OEM 88 Lph fuel pump = High volume, low pressure
T-Rex = Low volume High pressure (should have a feed pump by all rights)
Walbro 255Lph High pressure, in-tank pump = blows all of that garbage away
5.0LXStanger
22
Paso Robles, CA
Jul 2, 2025
#44
  • Jul 2, 2025
  • #44
Ok sorry for the delay, but she's all back together with the new Walbro 255lph fuel pump and the new fuel gauge sending unit. I started her up and she still runs rough at cold idle / warm up, but once she hunts around for about a minute she settled down and idles, eventually settling in about 750rpms. Once warm I took her for a test drive. Idle and cruising fuel pressure is now around 28-32psi. She seems to be running much better - No lean popping and lots of power. 2nd gear is like a time-warp - No problem busting the wheels loose and drifting a bit in 2nd gear around 30mph. At WOT I am now seeing between 55 to 60 psi fuel pressure. I think I have solved a major reason for my LXs poor drivability. She still wants to die when coming to a stop. I will now pull codes (again) and then follow the cold / rough idle diagnostic sequence. I have a feeling I am on the right track...
Reactions: Mcmahst, General karthief and AeroCoupe
Admin Dude
Jan 4, 1985
43,463
21,647
234
Box behind Walmart
Jul 11, 2025
#45
  • Jul 11, 2025
  • #45
Perform a [Base Idle Reset].
Reactions: 5.0LXStanger
5.0LXStanger
22
Paso Robles, CA
Jul 11, 2025
#46
  • Jul 11, 2025
  • #46
Good call! Plan to do that this weekend... Cheers!
Reactions: Noobz347
  • 3
First Prev 3 of 3
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
