1990 Mustang 5.0 Manual Gear Shifter Is Stuck!
with the car off, how does it shift?
if you double clutch during a shift (ex: car is in first rolling, depress clutch, pull shifter to neutral, release clutch. redepress clutch, shift to second, release clutch) does this solve the issue.
from experience, I think you're going down the road to clutch/TOB as likely the TOB or pressure plate has failed, but some other stuff to rule out first. could be a shift fork, etc.
Gonna assume a manual?
In which gear? Is clutch fully disengaged?
yes its manual 5 speed, just put new adjustable clutch cable on yesterday, yes it is disengaging all the way. right now it is stuck in first, it got stuck in third while i was driving it, beat it out and wouldnt stay in any other gear but third, when i can get it to stay in gear it sticks...
Sent from my iPhone 4S using Tapatalk
already checked bolts, they were good. right now its took apart to where u can see the inside of the box, it has the long part that goes thru trans, and the ball of the shift stick goes in, that part its still stuck in gear wont budge at all.
Try rocking the car back and forth while it is in gear. Then step on the clutch and try and move the shifter. The clutch fork or cable could be sticking.
What year car is this?
1990 mustang, its not moving right now, it did at one point. ( put new clutch cable on yesterday) didnt start having any problems till the first clutch cable broke tho
wont come out of gear either way
It will rock back and forth even in gear. That may be enough for you to shift to neutral when you depress the clutch. How far off the floor is the clutch engaging? Sounds like the cable is not adjusted properly.
yea it will shift into neutral, but it wont move side to side like it did before. my bf routed and adjusted the cable, i did the quadrant. he had problems routing the cable, we were told of two ways to route it, stock or some other way but both ways it was either on steering or touching the headers so not sure how it is now. looked for a routing diagram but couldnt find anything...
Uh, now it may be just me, but I think you found the problem.
