1990 mustang 5.0 wont start why?
tunertownz
i have a 1990 mustang it will turn over but slowly and won start car.... i can push start the car and it starts and runs great.... i have done everything i can think of .... new battery, new 1G cable battey to silinoid, new silinoid, new wires from silinod to starter, new starter, new cap and roder, new spark plug wires , i had altinator and new starter tested along with battery all good... engine is rebuild i drove it about 1k miles then after work one day it wouldnt start.... i had 10-40 oil in it its winter so i changed that to 5-20 so im out of things to do anyone have any ideas??? im stumped...
How are your ground cables?
If you turn on the headlights, do they come on and stay bright?
If you use a jumper battery, does it crank faster?
bad engine ground will probably make the car run like crap and buck in higher rpm. I forgot to tighten mine and the car started and idled fine, then got all messed up when I got on the gas.
The starter is the largest electrical-draw item on the car. In your case, the ground contacts were probably ok until the motor really started to sing, in which case continuity became intermittant.
