- Aug 26, 2016
- 3
- 2
- 1
Mustang GT solid car.347 Stroker built by Slawiak Racing with less than 1000 miles since built and at a cost of $7000 with the AFR aluminum heads,Scat,crank,Scat rods,Mahl forged pistons.Canton oil pan with stud girdle and engine dyno'd by Slawiak.I have receipts for all that and dyno sheet. Motor put out 424hp with a "ok" carb. Builder said easily450hp with what I have put on.Underdrive pully kit.SVE 130 amp alternator,SVE 3 core aluminum radiator with twin electric fans.Huge trans cooler.BBK SSI intake,BBK fuel rails,Aeromotive 340lph stealth fuel pump with new pickup and sending unit.BBK FPR.30lb injectors.BBK MAS,BBK Cold air intake.70mm TB.MSD AL box.New battery.Flowmaster 40s. AOD trans with aftermarket valve body.B&M shifter.Weld draglite wheels.New black carpet and headliner from LMR.Dyed plastic pieces.Triple gauges on pillar.New Sunroof seals and door seals from LMR.Car needs little. Needs gears and car would be in the 11s.Have not had time to drive or enjoy it and has just been collecting dust in the garage. I have over the asking price in just the motor and accessories not including what I paid for the car.Everything mechanical under 1000 miles since built.I also have a new aftermarket steering wheel and shorty ceramic coated equal length headers to go with the car.Door panels are on the car now. Might take partial trades on sandrails,dune buggys,lifted nice golf cart etc.$7000 Located in upstate NY.
