Electrical 1991 lx 2.3l convertible mustang
I know sorry for bothering you i was at it for hours yesterday , just trying to either use adapters in this picture or other solutions like use peice connector from amp short connectorss splice them from amp idk just trying to do it any way possible.
What bypass wiring you talking about, the radio?
In the forst pic is my harness completley removed idk why whoever had cut the end peice off from it but its for the speakers . The second peice is also cut as well .that may be why i am confused that goes directly to the radiohead unit.
If you are trying to put an aftermarket radio in, identify the 8 speaker wires. Front left, right, rear left, right. Take the radio harness and attach the speaker wires appropriately...there usually is even a diagram printed on the radio or instructions saying which colors are which speakers. You can probably find out online what the colors are for the speakers. Then find your always on battery power for the clock and memory, the ignition on for turning the radio on, antenna wire and hook everything up.
Otherwise, it sounds like you may need to either get someone to help or take it to Best Buy or something.
Thabks
