1991 supercharged 5.0 oil breather leaking/smoking
WesleyWard
Washington
Recently picked up a 1991 supercharged Fox Body. Noticed smoke coming from under the hood on the passenger side and looks like oil is leaking out of the valve/oil breather and dripping on the headers. The breather was also smoking a bit. From the research I've done the PCV valve should be plugged but have no idea how to find it. Could it be a problem with the breather itself?
Pictures would help. A bunch of people run a hose from the fill neck nipple to a baffled breather tank mounted behind the passenger fender.
The hose ruining from the intake to the PCV should have a checvk valve put in it.
