4 4bangerjames New Member Oct 27, 2011 3 0 1 Oct 27, 2011 #1 Oct 27, 2011 #1 I have coolant leaking near where my waterpump is. I have already replaced the lower coolant hose from the raditor to the pump and the lower heater hose. Is my water pump bad or do I just need to replace the gasket?
D Delray Dude New Member Jul 7, 2010 263 1 0 Oct 27, 2011 #2 Oct 27, 2011 #2 chances are that the water pump shaft seal is starting to go. if you are on the original pump - you are long overdue.
mg man Member Jun 24, 2006 142 0 16 Oct 27, 2011 #3 Oct 27, 2011 #3 When installing it going from memory some of the bolts go into the water passages. So thread sealant will be necessary. Maurice
