+1 typically the MAF will be calibrated with the injector size. so if you are running the stock ECU you will need a MAF that is calibrated for the 55lb injectors you plan on using. Now that will change if you plan on having the car tuned at a dyno shop, ask them what they recommend you to buy.. some tuners are more comfortable with one item over another.
